Thread: 89 idle issues
    Default 89 idle issues
    I have an 89 Sierra, 5.7. auto,When I first got it it had very hi idle. I replaced base plate gasket nad idle air control valve. It ran fine for about a week. Now it idles rough , especially in drive with brake on. I have replace plugs, wires, cap and rotor, Fuel filter . No change..any advice appreciated.No service engine light and no vacume leaks that i can find..
    Update:Changed tps , no change
    Disconnect your egr and plug up the barb on the carb/tbi. I have this problem with my egr hooked up.
    Old Show Trucks USA conversion
    Custom Paint, interior (Wood grain and leather seats) windows so dark you need a flash light to see me, stock rims, headers, dual exhaust.
    Sounds like your EGR valve is leaking. First unplug the vacuum line and see if that fixes it. If not, remove the EGR valve itself and see if there is debris around the pintle. You can make a simple block off by cutting a piece of pop can to fit the base of the EGR valve. It will turn on the Check Engine light, but it will get you going.
    Good Luck and God Bless
    Thanks for the replies, a little more info. I set the timing to 0 with the timing wire unhooked. Runs great, but, when driven it pngs and detonated terribly, so I have to retard the timing to get it to run ok, but still idles poorly. Is this still pointing to egr? all help appreciated..
    could also be the engine running too cold and trying to warm up.
    someone said these trucks are engineered to run at 210 so they burn cleaner....
    check how your plugs are burning too. that'll say it right there
  1. 1996 Tahoe irratic misfire at idle, runs fine off idle and cruise
    By tankdg1 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 09-17-2011, 06:11 PM
  2. 1994 TBI fuel + idle issues
    By weswins in forum GM Powertrain
    Last: 07-07-2011, 12:28 PM
  3. 2001 GMC Yukon XL - Brake Issues and Idle problem when wet
    By aljoy1 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 08-14-2010, 08:15 AM
  4. issues with idle
    By BigRed2500 in forum Performance & Fuel
    Last: 08-29-2008, 10:07 AM
  5. Idle Issues
    By trivers in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 11-17-2007, 01:39 PM
