Results 11 to 18 of 18
    People who are saying they have an MPG drop but haven't programmed their speedo, keep in mind that your MPG drop from a larger tire will be exaggerated because your odometer runs from the same sensors as your speedometer and they will be off by the same amount. While a larger tire will lower your MPGs, not reprogramming your speedometer will make it seem like a larger effect because the larger tire also has a larger circumference and you will travel slightly farther for each rotation of the tire. That means your odometer will also report less miles than you are actually travelling when you try to calculate your MPG.
    This is a correct statement.^^^^^^^^
    My examples were with a corrected speedo as well.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    I have a programmer in my truck... and swapping between stock and 33's changes my mpg an average of 2 mpg. Now just to do a difference in speed testing I had a friend follow running my stock tires when I had speedometer adjusted for the larger and speed difference was 3-5 mph at 45. I didnt test it the other way around as I just wanted to know the difference when I put my winters on and don't adjust the speedometer.
    Tim, you only did a "one-up" size change, which has negligible impact on performance or economy. It is the max that is recommended by virtually all tire retailers. You got a better look, and it didn't affect much.
    Aj,
    Your stock tire weighs about 39/40 pounds. The tire you will replace it with weighs 57 pounds! So, 17 pounds x4 is 68 additional pounds. Now, that doesn't sound like much, but it is "unsprung" weight, which is not at all like the same amount of weight being put into the back of the truck. Your truck will have to overcome more drag each time you accelerate. The diameter is about a 4% increase, which will likely make your speedometer run about 3 MPH lower than actual, and your odometer will be off by about 2 miles every 100. The speed and odometer errors can be corrected, but the mass/weight will always be there. You will love the way your truck looks, but you may not be too happy with the other changes.
    Quote Originally Posted by buckmeister2 View Post
    Aj,
    I was just sharing my info for just going up 2" in tire size. That amounts to 2 - 3 miles per gallon amounts to almost 50 - 75 miles a tank... or roughly 3 or 4 gallons of gas. That is just with about $13.
    Apr 2009
    North Dakota
    You never stop paying for that oversize rubber. You just can't beat physics.
    2013 Escape Titanium 4WD
    Aj,
    assuming we are talking bout tires of the same width here and tires of the same height, which for time saving purposes, lets say so....
    the 68 additional pounds from a tire of exactly the same size, is EXACTLY the same as 68 additional pounds distributed onto your truck, I get what some people say about this being rotational weight vs. static weight, but realize this, since the tires sit on the ground on a vehicle, if tire size hasnt changed, but weight has increased, then you will have the exact same effect from 68 additional pounds in rubber weight on your rims as you would from static weight in your bed. The only time acceleration, stopping distance, rwhp, etc. changes is when the tire width and/or tire height changes, not weight, unless it is an absurd amount.
    it really is just physics, something ive had too much of in the last few years LOL
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
  8. #18
    Jr. Mechanic GrizzlyTN's Avatar
    Jun 2010
    Jackson Tennessee
    I don't have a bunch of math and stats but I can recommend the Toyo Open Country MT's it's more a cross with an AT and the quietist MT I've ever rolled on. I had Nitto Mud Grapplers and they looked great and cut mud like a pro but they were loud as two coons screwin. Yes Toyo's cost more but if you're trying to get the "tough" look and mud capability without the road noise these are what you want.
    2012 Chevy Silverado Z71 4x4 5.3
    Rough Country 2.5' Lift/Level
    Chevy 18's on Toyo Open Country MT 33's
    DiabloSport Trinity Tuner with Custom Tune from Lew
    Debating on AMP Research Powersteps
    2008 GMC Sierra WT 4x2 4.3
    3" Rough Country Suspension Lift w/Control Arms
    Super 44 Flowmaster Straight Dual Exhaust from the Cat Back with 18" Chrome 3.5" Exhaust Tips.
    Moto Wheels 951 18" on Nitto Mud Grappler 33's
    Infinity Kappa Perfect 6.1 System with Kenwood 5.1 amp using Stock Headunit.
  1. All-Terrain Tires for 20" Wheels
    By PearlWhiteLTZ in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 12-03-2011, 02:39 AM
  2. 4- firestone 245/70r/17 all terrain tires,97% tread,almost new!
    By Bigbomber in forum Wheels & Tires Classifieds
    Last Post: 02-27-2011, 11:43 AM
  3. Best ALL Terrain for your $$$
    By ethan1029 in forum Lifted & Offroad Suspension
    Last Post: 04-19-2010, 12:54 PM
  4. All-Terrain Tires
    By CornhuskerChevy in forum Wheels & Tires
    Last Post: 01-01-2010, 02:19 PM
  5. 265/70/17 all terrain tires for sale
    By sierraman in forum General Classifieds
    Last Post: 04-15-2008, 11:51 PM
