    Default truch leveling info
    I have a 2000 Silverado reg cab/short bed. The po had put 265/70/17 tires on it. It had the stock ride height. I bought a set of shackles off ebay and 'lowered' it about 2 inches. It still seems a little high in the back end. What can I do to get it level?
    anyone? Could use some help. Do I need to raise the front alittle. If so, how?
    Jr. Engineer Jaele's Avatar
    Nov 2011
    Fairfield CA
    You can remove the shackles and purchase a leveling kit for the front end
    2011 Silverado 1500 Z71 4x4 Crew Cab
    LED Dome light
    LED Floor lights
    RC Leveling kit
    Tow Mirrors Custom LED running/signal lights
    BakFlip G2 Tonneau Cover
    Master Mechanic Burden33's Avatar
    Mar 2009
    Goose bay, Labrador Canada
    You can order another shackle or remove the blocks in the rear or do like he said and run a smal leveling kit
    Fabtech/Banks Ram Air |Fuel Off Road/ 315/70/17 duratracs |Hyper tech / Spencershids |
    Color Matched Bowtie |15% Tint on Front Windows|20% Tint on Back Windows
    Chevy Ridin' High
    what kind of small leveling kit?
    Default truck leveling
    Any help? What kind of leveling kit?
    Jr. Engineer UpsetProps's Avatar
    Mar 2012
    Calgary, Alberta, Canada
    1. Park on level ground
    2. Make sure box is empty
    3. Measure from the center on your rear wheel at the axle up to the bottom of the wheel well
    4. Measure from the center on your front wheel at the axle up to the bottom of the wheel well
    5. Subtract the measurements to find the difference
    6. Purchase a front end levelling kit that matches the difference
    ex: if you measure 42" rear and 40" front you need a 2" front leveling kit. (I just made these numbers up, don't use them as a guide.)
    - Nitto Tera Grapler 265/70R17, Line-X bed liner, Black Bowties, Stampede front deflector, DeeZee black diamond plate bed rails, TonnoPro Lo-roll cover, Antenna deleted, Spyder Projection Headlights with Phillips CrystalVision Ultra bulbs, Spyder Tail Lights & 3rd Brake Light, Rough Country leveling kit, PlastiDip'd emblems, and wheel hubs, Diablosport Trinity, 20% tint, Black OEM grill
    Last Post: 05-06-2012, 07:40 PM
  2. Replies: 0
    Last Post: 04-19-2012, 08:50 PM
  3. 3" lift kit leveling torsion keys ~ any install info instructions ???
    By jlbf0786 in forum Lifted & Offroad Suspension
    Last Post: 09-21-2011, 09:41 PM
  4. Silverado Leveling Kit Info for New Body Style (NBS)
    By DrewsZ71 in forum Lifted & Offroad Suspension
    Last Post: 09-24-2009, 01:13 PM
  5. 4.3L to 6.0????Need info
    By 94silveradodude in forum Chevy C/K Truck Forum
    Last Post: 01-27-2009, 04:52 PM
