Results 1 to 2 of 2
    Default 2003 yukon xl trans riding out 2-3 shift
    Hi, Last friday we got the boat out of storage I towed it home and I noticed that in tow haul mode the truck was riding out 2nd gear pretty long. We took it to the lake and all was ok other than riding out the gear. Took the boat off, drove about 300 miles, everything felt normal. I notice that when I take off from a light it is riding out 2nd longer than normal. Then it has soft smooth shift (I would not have known it shifted if the rpms did not drop) It does not do this every time. I Checked the fluid and it is clean and does not smell. I know nothing about trans internals. Any ideas what the issue may be? Thanks
    Sr. Engineer
    Dec 2011
    11-22-boogie woogie avenue
    Check tps voltages that it is a nice gradual rise no glitches from idle to wot.
  1. Trans wont shift in to OD?
    By mattheww in forum GM Powertrain
    Last: 03-07-2012, 07:58 PM
  2. 2003 Tahoe Lt, Trans Problems, slow to shift
    By BIGREDDADDY53 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 12-21-2011, 01:33 AM
  3. trans quick shift
    By grumpy old man in forum GM Powertrain
    Last: 03-12-2010, 09:28 AM
  4. Trans shift cable
    By thrasher in forum GM Powertrain
    Last: 02-26-2010, 09:35 PM
  5. trans shift problem
    By cokejim in forum GM Powertrain
    Last: 12-30-2007, 03:48 PM
