    Jr. Engineer Jaele's Avatar
    Nov 2011
    Fairfield CA
    Default 2011 Silverado headlight lens removal
    Has only tried this on a nnbs headlight? Im thinking about trying the oven way later this week. If anyone have done this do you have a how to? i can only find them on nbs and obs styles.
    Thanks
    2011 Silverado 1500 Z71 4x4 Crew Cab
    LED Dome light
    LED Floor lights
    RC Leveling kit
    Tow Mirrors Custom LED running/signal lights
    BakFlip G2 Tonneau Cover
    Master Mechanic
    AMac's Avatar
    Feb 2012
    New England
    This is fairly easy to do however you have to remove the grille and the grille clips can be a pain. there is a 10mm bolt down low that is reachable through the wheel-well. Then I think there are two top bolts to remove.
    The following video should be able to guide you through the process.
    ---------- Post added at 04:02 PM ---------- Previous post was at 03:56 PM ----------
    re-reading the post/thread title, I don't think I answered your question. You are obviously asking about the lens and not headlight removal from the truck, sorry about that.
    Nov 2011
    Fairfield CA
    LOL its ok, I took it apart the other night to see what i was getting into. But yes im trying to remove the amber lens in the actual headlight
    Based on experience with the NBS headlights, I don't recommend the oven method. I've personally found it just makes the plastic warm and annoying to handle ... for what little it helps with the adhesive. Now a heat gun is a different story and I do use one of those while working the material in localized areas.
  1. 2011 Silverado LT Dash Trim Removal
    By Rymanh24 in forum Audio, Video & Gadget Tech
    Last: 08-04-2011, 03:35 AM
  2. 08 Sierra Headlight Removal
    By sstoner911 in forum Chevy Truck Accessories
    Last: 05-13-2011, 10:34 PM
  3. Headlight removal on a 2007+ Burban
    By Sandhopper in forum General Chevy & GM Tech Questions
    Last: 08-08-2010, 07:27 PM
  4. 08 Silverado Headlight lens haze
    By rwmoorh in forum Chevy Silverado Forum (GMC Sierra)
    Last: 10-30-2008, 09:44 AM
  5. Aftermarket headlight lens / housing VS OEM
    By randyb2004 in forum Chevy Truck Accessories
    Last: 11-18-2007, 01:15 AM
