    Default Couple new additions, couple more questions
    Well its been quite a while since i've posted around here. I've added a few new things recently and have some more projects in the works already. Anyways pictures are worth a thousand words so here we go.
    Wheel well liners, definitely a must have just because of the simple fact they make it so much easier to clean mud up.
    But the big project was wiring up some LED lights for the bed. It turned out pretty well I think, major PITA to run wires although I made it difficult because of where I wanted my switch.
    Anyways on to some questions, first up how can I pull out the plastic box between the power outlets? Do I have to pull the entire dash apart or what?
    Second question, I am thinking of making a lighted door sill similar to this:
    Anyone ever done something similar? I've pretty well got it planned out, I think I'm gonna try to do it with SILVERADO.
    Anyways thats all for now, I've got a set of foglights coming that should fit in the factory openings but actually provide enough light to be worth having. If it all works out well I'll have a set of factory fog lights for sale.
    2008 Silverado Z71 Crew Cab
    Spray in bedliner, Coverking seat covers, Bushwhacker bed caps, Lund bug guard, Husky splash guards, Weathertech floormats, rear wheel well liners, toolbox, Raptor Series running boards
    Soon to be attending Kettering University
    So do you have those factory fogs for sale?
    LB7|2" lift|20" rockstar xd's|wrangler mud tires|Leer cap|4in turboback|volant CIA|boost increase valve|EFI by DTS|phantom gauges|6 speed ZF-6|solid mass flywheel|ceramic Kevlar clutch|High idle switch|55 gallon in bed fueltank|Edge insight|4 rigid dually|app radio 2|250watt kicker amp an 10" sub
    Sr. Apprentice feb's Avatar
    May 2011
    Louisiana
    stewart7225 - Does the wheel liners hold the road noise? Is it any louder in the cab with the liners installed?
    Won't know for sure about the fogs until I get the new ones here and installed. If the new ones won't fit in the factory holes then I will be keeping the factory fogs.
    I don't think that the liners change the noise level any. The only difference is that I can hear more rocks that my tires kick up but that is only on gravel roads and due to my A/T tires.
    Master Mechanic Burden33's Avatar
    Mar 2009
    Goose bay, Labrador Canada
    i pulled the whole cover off its just held by clips. i know the holder comes out but i had my dash face off anyways since i was doing my stereo and i drilled a hole for my amp knob so i oculd turn up the bass or turn it down when i wanted
    Fabtech/Banks Ram Air |Fuel Off Road/ 315/70/17 duratracs |Hyper tech / Spencershids |
    Color Matched Bowtie |15% Tint on Front Windows|20% Tint on Back Windows
    Chevy Ridin' High
    Did you every get the LED lights done successfully?
    Quote Originally Posted by Jason2325 View Post
    Chickened out until I can find a cheap set of replacements in case I screw up lol.
    I do believe it can be done fairly easily but I still would like a spare set of door sills to work on.
    I did get my fog light replacements in, so if anyone is interested I do have a set of factory fog lights for sale.
    Check out my forum on what I want to do it's kinda of similar to you. Let me know what you think.
    http://www.gmtruckclub.com/forum/sho...838#post483838
  1. New here -- Just have a couple questions
    By Shadowness in forum Chevy Silverado Forum (GMC Sierra)
    Last: 02-20-2012, 12:55 AM
  2. New here from CT, have a couple questions:
    By Zbyler in forum CT - Conneticut Chevy Truck Club
    Last: 02-09-2011, 08:52 PM
  3. new here... couple questions
    By mx152 in forum General Chevy & GM Tech Questions
    Last: 07-26-2009, 11:01 PM
  4. Couple questions
    By jlsparky7 in forum GM Powertrain
    Last: 01-16-2009, 11:39 PM
  5. I have a couple questions
    By BuckeyeBandit in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 06-24-2008, 04:21 PM
