Results 1 to 10 of 12
    Default New GMC Sierra owner - some dumb questions
    I've recently purchased a 2012 GMC Sierra 1500 Ext Cab with the 5.3 engine and have a couple of dumb questions:
    1) As I've always changed my own motor oil and oil filter, today I crawled under the trucl to take a look for the oil filter and oil drain plug, I noticed that the drain plug is on the side of the pan - which means that when it's removed, the oil will come out horizontally and with many body parts in close proximity - I'm just wondering how this can be done without having oil all over the place
    2) On this truck, there is about a 3" plastic piece attached below the front bumper - What purpose does this piece serve ?? It definitely reduces ground clearance as I nearly rip it off on a parking lot curb stop. I'm thinking of taking it off cause I can see me acting as a snow plow in the winter
    Thank you
    Richard (Winnipeg, MB Canada) - 2012 GMC Sierra 1500 SLE 4x2 (Carbon Black Metallic) -Z71 - 5.3 L V8 - 3.42's
    Leer 100R truck cap; Chrome clad aluminum wheels (18"); custom cat-back dual side exits (4" diameter Magnaflow SS tips) exhaust system with Magnaflow muffler (18"); Cloud Rider stainless steel grill overlay
    better be careful with that drainplug seems somebody posted it's made of soft metal and will strip and I'm not sure but may need a special socket
    When you first pull the plug hold the pan up close to the drain for a minute and then set it on the floor.
    The air dam is there to help fuel economy and removing it will hurt it some.
    The airdam as was pointed out diverts air under the truck to increase MPG, how much is one for the engineers to answer.
    Another reason for the air dam is it assists in engine cooling, helps to create a low pressure area behind the bumper for air to pass through and help cool the engine, again how much is for the engineers to answer.
    A few people have removed the airdam and not noticed any negative affects.
    I watched the mechanics at the Chevy garage change my oil yesterday (first oil change was free, probably do it myself from there on) and they held the pan up close to the oil drain hole at first then let it down, afterwards he sprayed a degreaser on the area splashed with oil to clean it.
    I have personally removed the air dam from all three of my NNBS trucks with zero negative effects. In fact, my 08 gets better mileage than most people are posting as it is. IMO: its just something else to cause wind drag that your truck has to put power out to make up for... screw engineers. I have to deal with engineers' behind a desk making orders that don't make any sense and actually cause problems out in the field every day for the most part haha... so.. yeah. School/desk time is no comparison to actual application of knowledge.
    "Truck Norris"
    - 2008 TX Edition Silverado
    - McGaughy's 4/5 Drop Kit
    - Apline Type R 10s & Amp
    - Airaid CAI
    Thanks to all - your responses have been very helpful.
    I ended up removing the air dam cause when I looked at it more closely (after hitting the curb stop), I noticed that the screw on the driver's side was ripped out and so the air dam was flapping in the wind. With my truck only being a 2WD, that air dam really lessens the front end clearance.
    I wonder which engineering genius decided to put the drain plug where they did - probably never tried changing the oil themselves
    Quote Originally Posted by carbon black View Post
    He's an engineer he makes enough money to hire fools like us to do that for him.
    I've changed my oil a number of times, and never had an issue. The wind will blow it once in awhile, but that's about the only problem I've ever had.
    2009 GMC Sierra 5.3L running on E85
    Black and chrome
    Volant CAI
    Borla dual exhaust
    Chrome Billet grill
    Tonneau cover
    4300k High/Low Beam HIDs
    Westin Ultimate Bull Bar with PIAA 540s
    Blacked-out tail and third brake light
    Better aerodynamics equals less wind resistance and better fuel mileage, the wind tunnel does not lie. The less air that goes under the vehicle = less turbulence from under chassis components to slow the vehicle down.
    Quote Originally Posted by redvett View Post
    ...I just lowered mine to make up for the space the valance took up, so I therefore didn't lose any aerodynamic "points". I WIN! haha, jk. Yes simple aerodynamic laws will state that you're correct. But... we drive trucks.. not Ford Fiestas. MPG goes out the window with the convenience and security of being larger than those opposing forces coming towards us who only pay 45$ to fill up. And my truck (although it's becoming close) isn't fast enough to have to worry about air getting under it, causing upwards pressure and losing traction. And once it IS that fast, Ill have my bed cover I just won on here and my RST wing installed already anyways. So that, too, is cancelled out. Right?!
  1. New owner, a few questions
    By kennya in forum Chevy Silverado Forum (GMC Sierra)
    Last: 05-11-2012, 09:08 AM
  2. New Tahoe owner! got some questions
    By washyourrhands in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 10-22-2009, 09:36 PM
  3. New Owner/Synthetic Questions
    By Schutzund in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 02-19-2009, 06:54 PM
  4. New 89 owner with some questions
    By aresf11 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 05-02-2008, 09:02 AM
  5. New guy, new owner questions
    By EdPDX in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 12-12-2007, 09:03 PM
