    Default Where is INTERNAL fuse box?
    I have a 2004 Colorado that has the usual disease for these (burned-out resistor pack for the blower motor). I want to investigate and fix it. However, the passenger-side air bag is in that area and I want to disable it first. There is the problem. The owner's manual does not offer any useful information about accessing the interior (not the one in the engine compartment), fuse Box. And, the Haynes manual just says that the interior fuse box is, "...at the left end of the instrument panel...", and goes on to say that the fuse for the air bag is in there and should be removed before working near the air bag. To further confuse, using a search engine, there have been references to a fuse for the air bags inside the engine compartment fuse box that is referenced as "SIR" in that location.
    Questions: Where and how do I get at the interior fuse box. And, what is that stuff about an air bag fuse in the engine compartment fuse box?
    Pictures would be nice.
    Thank you much for any input on the above subject.
    If you open the driver side door there should be an access panel that you can remove to get to the fuses inside the cab. as for the location of the airbag fuse I am not sure.
    2011 Silverado 1500 Z71 4x4 Crew Cab
    LED Dome light
    LED Floor lights
    RC Leveling kit
    Tow Mirrors Custom LED running/signal lights
    BakFlip G2 Tonneau Cover
    Lots to come!
    Quote Originally Posted by Jaele View Post
    Unfortuantely, there is no access panel there. Unless you mean a little 2"x2" square on the upper area...but that is way to small to be an "access panel".
    Jr. Engineer
    Mar 2012
    Calgary, Alberta, Canada
    I'm not 100% sure but I don't think your truck has an interior fuse block.
    According to the manual your air bag fuse is in the engine fuse block.
    Check out page 5-106 and 5-107 of the manual.
    2004 Chevy Colorado Manual
    Last edited by UpsetProps; 05-28-2012 at 02:00 PM. Reason: Added the proper manual
    - Falken Rocky Mountain ATS 265/70R17, Line-X bed liner, Black Bowties, Front air dam removed, Stampede front deflector, DeeZee black diamond plate bed rails, TonnoPro Lo-roll cover, Antenna deleted, Spyder Projection Headlights with Phillips CrystalVision Ultra bulbs, Spyder Tail Lights & 3rd Brake Light, Rough Country leveling kit, PlastiDip'd emblems, and wheel hubs, Diablosport Trinity, 20% tint
    Next Planned Mods:
    Black billet grill inserts
    This is from chiltons on a 2004 Colorado fuse box and fuse location in the pictures below
    Disarming The System
    1. Turn the steering wheel so that the vehicle's wheels are pointing straight ahead.
    2. Turn the ignition switch to LOCK, remove the key, then disconnect the negative battery cable.
    3. Remove the SIR fuse from the fuse block.
    4. Remove the steering column filler panel or knee bolster.
    5. Unplug the Connector Position Assurance (CPA) and yellow four way connector at the base of the steering column.
    6. Remove the Connector Position Assurance (CPA) from the passenger yellow four way connector located behind the glove box.
    7. Unplug the yellow four way connector located behind the glove box.
    8. Connect the negative battery cable.
      Arming The System
    9. Disconnect the negative battery cable.
    10. Attach the yellow four way connector located behind the glove box.
    11. Install the Connector Position Assurance (CPA) to the passenger yellow four way connector located behind the glove box.
    12. Turn the ignition switch to LOCK, then remove the key.
    13. Attach the four way connector at the base of the steering column and the Connector Position Assurance (CPA).
    14. Install the steering column filler panel or knee bolster.
    15. Install the AIR BAG fuse to the fuse block.
    16. Connect the negative battery cable.
    17. Staying away from the air bags, turn the ignition switch to RUN and make sure that the AIR BAG warning lamp flashes seven times and then shuts off. If the warning lamp does not shut off, make sure that the wiring is properly connected. If the light remains on, take the vehicle to a reputable repair facility for service.
    Attached Images Attached Images
  1. What fuse is my third brake light fuse?
    By b_burdine in forum General Chevy & GM Tech
    Last Post: 11-04-2009, 07:18 PM
  2. P1825 Internal mode switch: value out of range
    By harristw in forum GM Powertrain Tech
    Last Post: 10-19-2009, 09:55 AM
  3. OBD fuse
    By 9191gmc in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 09-10-2009, 03:51 PM
  4. rear lights indicators Internal fuse blows
    By bensdive in forum General Chevy & GM Tech
    Last Post: 02-22-2009, 07:25 AM
  5. Internal Wheel/Tire Sensors
    By Steve in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 12-22-2006, 08:39 PM
