    Jr. Engineer UpsetProps's Avatar
    Mar 2012
    Calgary, Alberta, Canada
    Default Spyder Tail Lights collecting dust inside
    I have Spyder Tail Lights model #:
    ALT-YD-CS07-LED-BK
    The past two weekends of driving down dirt roads to go camping has caused them to get quite a lot of dust collecting inside, it is very unsightly with the clear lenses and black internal housing of the light. Just thought I would give a heads up to anyone looking at purchasing these in the future.
    I am going to attempt to fix this. I might try using a computer air duster through the reverse bulb hole to blow the dust out. Alternatively I may end up using VHT Niteshades to slightly tint them to make it less noticeable. I supose buying a darker lens to begin with would help alleviate this problem, but live and learn I guess.
    Does anyone have any other suggestions? Or had a similar problem before? Please post any ideas you have (and don't say buy RECON!)
    I will update this thread with any progress I make.
    - Nitto Tera Grapler 265/70R17, Line-X bed liner, Black Bowties, Stampede front deflector, DeeZee black diamond plate bed rails, TonnoPro Lo-roll cover, Antenna deleted, Spyder Projection Headlights with Phillips CrystalVision Ultra bulbs, Spyder Tail Lights & 3rd Brake Light, Rough Country leveling kit, PlastiDip'd emblems, and wheel hubs, Diablosport Trinity, 20% tint, Black OEM grill
    Master Mechanic
    AMac's Avatar
    Feb 2012
    New England
    That could happen if the bulbs are not secure, such as the backup bulb. I would clean them out and make sure the seal is tight. If it still happens then I would put an extra layer of sealant on the aftermarket tails.
    Mar 2012
    I checked and the reverse is tight. The connection to the LED portion is not sealed at all though. The wires just come out of the hole where the bulb would go if they didn't have the strip of LEDs. When I take it off to clean I will snap a picture of the inside.
    Master Mechanic
    AMac's Avatar
    Feb 2012
    New England
    yes I would check areas where the bulbs would go into to see if there are any gaps that would allow dust to get in like you have pictured. When you examine the light check for any other areas that may contribute to your issue. Could there be gap in the sealant for the lens?
    My Led taillights actually have a dummy fitting that goes into the open hole that no longer has a bulb in it. the wires run through the dummy fitting so maybe you can get a socket and mod it to allow the wires to run through and seal it up. Sounds like spyder overlooked this issue. I just removed my taillights to put in led reverse bulb and it was pretty dirty behind them but inside the housing itself is still clean. Good luck!!
    Mar 2012
    Thanks Phantom, I was also thinking about making a dummy plug as well.
  1. No instrument panel lights or tail lights? 97 Suburban, Help!
    By dslemaire in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 02-02-2012, 12:27 PM
  2. Spyder LED Tail Lights - Smoke
    By Jplindquist in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 04-24-2011, 04:06 PM
  3. new front grill and lights/ led tail lights
    By Dontlookforme in forum Chevy Truck Accessories
    Last Post: 10-03-2010, 04:19 AM
  4. Trading My Stock Tail Lights for Euro Tail Lights
    By ippielb in forum Chevy Truck Accessories
    Last Post: 07-10-2009, 11:50 AM
  5. Lost dash lights and tail lights???? [Expired Topic]
    By martone68 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 03-12-2006, 07:02 AM
