Results 1 to 10 of 19
    Sep 2011
    Rockwell, North Carolina, United States
    Exclamation Alternators burning up on my 1985 Silverado
    So Ive restored my 85 chevy back to mostly factory appearing, plus all my customizations. Ever since I have put the truck back together I have had alternator problems, if they're charging they're squeaking, no matter how tight/lose the belt is. If they're not squeaking, they're not charging. Ive even tried a "one wire" alternator and it burned it up. The other day me and a another guy completely went thru all the wiring and found a few problems and straightened a few things up. I got a new alternator to charge and not squeak and then i tied all my wires up and fired it back up and it squeaked, here is what i have found: if i test the regulator(brown/White/keyed power) wire on the alternator while its plugged in to it, it reads 3.15 volts but if you unplug it, it reads 11.57 volts like the rest of the truck. Whats going on here? is something burned up or not right? The alternator screams, is the 3.15 volt wire not allowing the alternator to fully engage hence the squeaking..
    Thanks,
    Royce
    BUILT, NOT BOUGHT
    1985 Chevy Silverado Longbed 4WD
    400 Chevy Small Block/400 Chevy Transmission
    Detroit Lockers Front & Rear/4.10 Gears
    35" BF Goodrich Mud Terrains/6" Rough Country Suspension lift
    Sep 2011
    Any advice from anyone?
    Sounds like you may have a wire that has some insulation missing. If it worked while the wiring was loose and down, but not when it's bundled nice would indicate that to me. Just gotta chase down wiring and find the bad wire.
    Christopher
    you have a hot wire grounding check down by the starter make sure there is nothing touching.
    Let me get this right, you have a 85 Chevy, with a v belt alternator, and the belt squeals when it's charging, but if you tighten up the belt, the alternator still turns but it doesn't work? What I know is this, V belt alternators squeal when the draw or load on the alternator exceeds the belts grip, so the belt squeals due to slip. Is the belt new or old? Has the battery been checked by a GOOD tester? Have you added aftermarket sound, lighting, or anything else that might place more of a load on the electrical system than a stock truck? If so, you may need to add a second alternator and battery to keep up with the load.
    Turn the truck off completely and remove the battery cables from the battery, and check them with a meter to see if you have a leak. Sounds to me like a short somewhere is causing a huge drain on the charging circuit. Have you replaced the main battery cables? Do you mean to say the truck burned up the one wire alternator, or the one wire alternator burned up the belt? What do you mean by this exactly? "
    Brian Larson CST. KC9DAK.
    Janesville WI.
    87 GMC G20 6.2 diesel.
    Quote Originally Posted by RallySTX View Post
    Exactly, this is your problem, you proved it with the "it reads 11.57 volts like the rest of the truck" statement.
    Sep 2011
    The battery is brand new, just replaced it trying to track this problem down. Cables are fairly new, not worn.
    This was a 78 amp factory style alternator. Yes I have a Sound system but its all on a separate circuit and the alternator still acts the same when it is unplugged.
    Quote Originally Posted by kw70chevy View Post
    Second thing I checked.
    As of RIGHT NOW I have fixed this issue with Replacing the Alternator again, so far so good.
    Quote Originally Posted by Royce Lancaster View Post
    Ok, but a fully charged battery should read 12.5x, not 11.57, was this a typo?
    Sep 2011
    Its just what the battery was reading at the time, from constantly starting the motor with out the alternator charging, and driving around for a day with out it charging.
    Yeah, I was afraid of that one, I have had a couple people go through several new alternators before they actually got a good one, that happens. I hope the trouble is fixed.
    Brian L.
  1. 2007 Silverado 4x4 Burning Oil @ Alarming Rate
    By koolbia in forum Chevy Truck Tech Forum
    Last Post: 01-25-2013, 02:34 AM
  2. Able to Swap Alternators?
    By bama2010z71 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 10-24-2011, 09:19 AM
  3. help with batteries and alternators
    By elkosp16 in forum GM Electrical Tech
    Last Post: 08-17-2010, 01:36 PM
  4. Alternators.... How long and how beefy can you go? [Expired Topic]
    By MN_Burbon in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 09-23-2006, 05:29 PM
  5. Info on beefed up alternators <link> [Expired Topic]
    By Dr_Zero in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 03-15-2006, 04:54 PM
