    Sr. Mechanic Ridyn's Avatar
    Feb 2011
    Waco,TX
    Default Trailer running lights question
    I have a 2012 Silverado crew cab with the HD towing package and cooler and the 3.42 gears, I had connected my fathers trailer after re-wiring it for him, and every light worked except for the running lights when the headlamps were on.
    However when I connected the trailer to my sisters truck which is an older model like a 2002 ext cab, it worked just fine.
    Question here is, do I have to have a special type of hitch connected so the truck knows that it's about to tow in order to engage the running lights for the trailer connection in the rear or do I need to take it to the dealer so they can have a look to see if it was even installed correctly from the factory?
    Please respond asap, I haven't pulled a trailer yet and this was supposed to be the first time...so I have never messed with the truck for towing until now.
    "Never ask a man if he's from Texas. If he is, he'll tell you. If he isn't, there is no need to embarrass him."
    2012 Silverado 1500 Texas Edition 4x4 LT skid plate, 5000k 55W low beams with DRL fuse removed, 5000k 35W fog lamps.
    Leveling kit and tires coming soon.
    Leaving for boot camp at MCRDSD 20121008.
    Running light circuit is not getting power. For some reason on your new truck it sounds like the plug has that connection in a different location than what your trailer thinks it is supposed to be. At this point, I take my truck to my auto electric guy. Of course, he may want to take a look at my wiring job on the father's trailer, or suggest trying your truck plug on a different trailer to see if the problem persists.
    And other vehicles and toys.
    Have you checked your fuse for the running lights if you have one?
    Current:
    Future:
    Sr. Engineer
    Oct 2010
    Indianapolis, In
    Try looking here, http://www.gmtruckclub.com/forum/sho...agrams-Pinouts . Before you start changing wiring on a new vehicle I would make sure the trailer wiring complies with the diagrams in this post. I don't know the history of the trailer but if it was normally towed with sisters truck then maybe it was wrong and trailer was wired to work with it. If you have electric brakes then make ABSOLUTELY sure it is wired correctly, last thing you want is turn signals working the brakes.
    Good luck and be safe.
    Sr. Engineer
    Oct 2010
    Indianapolis, In
    Hey Mods, can you move the trailer pin out sticky http://www.gmtruckclub.com/forum/sho...agrams-Pinouts to the trailer towing site?
    Very good idea. Done. I also left the link in the Electrical sub-forum for posterity.
    Christopher
    Sr. Engineer
    Oct 2010
    Indianapolis, In
    even better!
    Feb 2011
    Waco,TX
    It was a fuse that was blown out! Had the dealer look at it, I felt like a dumb butt of course.
    They even made sure that it wasn't the vehicle making t blow the fuse, so I guess I'll just try it again tomorrow when I go pick up the trailer.
    If I'm correct, it was my fault the fuse blew anyway >.> good story for a different day though!
    Thanks for all the input as all guys!!!
  1. Trailer lights not working 2003 Silverado
    By Highmarker in forum GM Electrical Tech
    Last: 09-01-2011, 06:16 PM
  2. 1999 suburban daytime running lights question
    By ochs99 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 04-15-2010, 06:44 PM
  3. 94 GMC suburban,rear running lights/dash lights fuse?
    By Rancor2001 in forum General Chevy & GM Tech Questions
    Last: 12-21-2009, 07:24 PM
  4. Can i use 3157 lights for my day time running lights?
    By badassbowtie in forum General Chevy & GM Tech Questions
    Last: 07-08-2008, 02:22 PM
  5. Trailer lights [Expired Topic]
    By samoraml in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 06-28-2006, 09:23 PM
