Results 11 to 17 of 17
    Quote Originally Posted by Chris Miller View Post
    If the lift/duration is much more than stock, you may have to get your computer adjusted. It may well not be delivering the right amount of fuel at the right time for the new cam. Plus, as the above poster said, make sure the timing is set right, and ask the guy who installed it if he degreed it properly.
    ...1988 350.. were those tbi and computered? was thinking it shouldn't be, but i haven't dealt with that year model truck really.
    if that were the case then i could see it being the issue as well. hopefully someone will chime in on it also soon.
    "Truck Norris"
    - 2008 TX Edition Silverado
    - McGaughy's 4/5 Drop Kit
    - Apline Type R 10s & Amp
    - Airaid CAI
    They had OBD-I systems, which could still be finicky with a big cam.
    Ahh.. 10-4. Good to know thanks.
    Hope this guy figures out his problem
    "Truck Norris"
    - Airaid CAI
    the intake was 204 and the exhaust was 214 i know the stock intake is like 194 but i put the cam in myself. im ready to tear the front apart just to double check the timing but when i put a light on it the line is all over the place
    Quote Originally Posted by wiles S View Post
    Is this your first cam install? (just out of curiosity) and what brand cam is it? Did it come with the timing gear pre-installed?
    "Truck Norris"
    - Airaid CAI
    ya it is the first one i did and it was a summit racing brand i just used the gear off the old cam but i went back and checked everything. im thinking i need more fuel
    Did you remember to disconnect the timing wire when you checked it? That would cause the line to jump when you put a light on it.
    On that one it should be in the relay box on the firewall. It's a tan wire with a black stripe.
  1. 7.4L 454 big block not starting or running with gas
    By Crawdaddy in forum GM Powertrain
    Last Post: 12-01-2010, 07:09 PM
  2. troubles with a 98 diesel motor starting/running
    By renegaderider in forum GM Powertrain
    Last Post: 04-26-2010, 08:17 AM
  3. starting issues
    By pidford in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 04-10-2010, 09:40 PM
  4. starting issues
    By dlaude6 in forum General Chevy & GM Tech Questions
    Last Post: 03-24-2010, 07:44 PM
  5. 02 Silverado starting/ running problems
    By greensilverado in forum General Chevy & GM Tech Questions
    Last Post: 06-15-2009, 11:43 AM
