Results 1 to 2 of 2
Thread: 6.2 engine swap
    Default 6.2 engine swap
    I have a 2009 silverado that had a 5.3 lmg motor that I am wanting to swap with a l9h 6.2 from a gmc. I have the 6l80 tranny so it should be a direct swap but the l9h has vvt and I am wondering if I can just switch over ther timing chain sprocket and cover to eliminate the vvt and what advantages and disadvantages will it have?
    Also if I wanted to go with the vvt how would I go about since my ecu and harness was not equiped for vvt?
    The first pic is the one with vvt
    Thanks
    My guess would be that to make that swap work, you need the entire system, motor, harness, and ECM. Try what you asked about, and I suspect you will give your onboard ECM a lobotomy. But I'm just guessing, I have no experience with the newer trucks.
    Brian L.
    Brian Larson CST. KC9DAK.
    Janesville WI.
    87 GMC G20 6.2 diesel.
  1. 85 Sub 1 ton 454 engine swap and tailgate to barn door swap.
    By RallySTX in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 05-19-2012, 09:26 PM
  2. Engine swap need help
    By mixednuts in forum Member Introductions
    Last Post: 12-03-2011, 09:58 PM
  3. Engine Swap
    By Lgriffi in forum General Chevy & GM Tech Questions
    Last Post: 02-06-2010, 10:37 AM
  4. engine swap
    By peabody_80 in forum General Chevy & GM Tech Questions
    Last Post: 04-27-2009, 07:27 PM
  5. Engine swap (4.8 to 5.3)
    By Jake in forum GM Powertrain
    Last Post: 04-14-2008, 11:44 PM
