    Default Putting red LED lights in a 02 silvrado dashboard
    Ok so I saw a forum on this I'll leave a link below. But my Idea is to take the cassette player out and put in read LED lights with a clear cover cut out in the word ALLISON. I want to sync it with my dash lights to so I can dim it at will. The red led lights are no problem finding. I just need help with finding a clear cut out saying ALLISON and how I can sync it with my dash lights.
    Forum-http://www.gmtruckclub.com/forum/sho...067#post478067
    Here is where I got the Idea
ID:	40863 Click image for larger version.
ID:	40864And here is where I would like to put the LEDS (in the read highlighted area)
    LB7|2" lift|20" rockstar xd's|wrangler mud tires|Leer cap|4in turboback|volant CIA|boost increase valve|EFI by DTS|phantom gauges|6 speed ZF-6|solid mass flywheel|ceramic Kevlar clutch|High idle switch|55 gallon in bed fueltank|Edge insight|4 rigid dually|app radio 2|250watt kicker amp an 10" sub
    That is probably something you are going to have to make from a material like plexiglas. lightly scribe the logo backwards into the back of the piece, then paint it black. Drill holes to mount the LEDs into each edge of the plexiglas and insert an LED. Paint over the LEDs or in some way, block the LED so it doesn't let off any direct light. That should do ya.
    I get the hold mounting it into the Plexiglas but painting over the led so it does not let off direct light is foggy to me. I'm not getting what you are saying.
  1. Switching OEM Dashboard Lights for LEDs?
    By asa.prevost in forum Chevy Truck Accessories
    Last: 03-28-2011, 01:05 AM
  2. My truck after putting on recon lights
    By gotatruck in forum Photo & Video Gallery
    Last: 06-18-2010, 06:13 AM
  3. Replacing Dashboard lights
    By Falcone in forum General Chevy & GM Tech Questions
    Last: 04-26-2009, 11:27 AM
  4. Dashboard console lights [Expired Topic]
    By Taggart in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 01-06-2007, 04:37 PM
  5. Dashboard console lights
    By Taggart in forum Chevy Silverado Forum (GMC Sierra)
    Last: 12-31-1969, 08:38 PM
