Thread: Shock help
    Jr. Engineer lsutoms's Avatar
    Sep 2009
    baton rouge louisiana
    Default Shock help
    I have a 2009 silverado 1500 lt with the 5.3L flex fuel. I'm ab to roll over 70,000 miles and I've noticed my ride seems more bouncy ESP when hauling trailers which is pretty regularly. Could my shocks be worn out already? If so what shocks should I replace them with? Should I put heavy duty shocks since I'm hauling regularly and also put load leveling air bags? Or maybe just heavy duty shocks. I also thought about putting regular shocks that are close to my stock ones and putting air bags. I have an onboard air system so the air bags would only run about $230. Any help would be great! Thanks!
    "I'll Sleep When I Die"
    2009 Chevy Silverado LT1
    295/70/17 Toyo MT's
    2" rough country leveling kit
    CAI
    magnaflow exhaust
    custom tune
    spray in Line-X bedliner
    deep low profile took box
    6000K HID's
    5% + 20% tint on door windows and rear + layer of 10% rear glass and 5% tint strip
    2 12" Kicker CVT's
    custom sub boxes
    1000 watt hifonics sub amp
    4 6.5" hifonics door speakers
    4 hifonics tweeters
    320 watt hifonics amp
    Quad bell train horn
    5 gallon air tank with 100% duty Viar compressor
    galls street thunder deluxe siren/PA
    Sep 2009
    I should also add that I'm running 295/70/17 Toyo mt's. Thought that this combined with hauling could be a reason that they would be worn out already
    295/70/17 Toyo MT's
    CAI
    magnaflow exhaust
    custom tune
    6000K HID's
    2 12" Kicker CVT's
    custom sub boxes
    4 hifonics tweeters
    Quote Originally Posted by lsutoms View Post
    As you Regularly Tow and Haul Trailers, and having 70K Miles and now your ride is now more bouncy, its possible your Shocks could be worn out??.......going with Air Bags as much as you Tow/Haul, would be the way to go, along with a Set of New Shocks,
    I'm running with Edelbrock IAS Shocks and Air Lift Rear Air Bags, and with this setup......the Ride Comfort and Handling is Excellent when Towing, also having a On-Board Compressor, along with the Gauge and Controls in the Cab, this allows me to Adjust the Air Bags for the Change in either the Ride or Road Conditions.....
    also check out Bilsteins HD shocks, but airbags for sure for your towing needs
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
    Former Member
    Apr 2012
    Reading, PA
    Airbags can negatively affect the ride by making it "pogo" more...I have had this happen when loaded heavy and a lot of air in the bags. They seem to amplify the rolling bumps...
  1. Shock Help
    By groceryman in forum Lifted & Offroad Suspension
    Last Post: 10-06-2011, 09:57 PM
  2. Need some shock input 02' XL.....
    By Staged in forum Lifted & Offroad Suspension
    Last Post: 05-18-2011, 09:23 PM
  3. What are the best shock to buy
    By rlarsen247 in forum General Chevy & GM Tech Questions
    Last Post: 12-08-2009, 07:24 PM
  4. lil shock help?
    By jiujitsu in forum Lifted & Offroad Suspension
    Last Post: 01-05-2009, 07:13 PM
