    Default 2006 3500 diesel Silerado
    I've been listening to the A/C fan bushings squeak for weeks. Now the fan just quit. I am guessing that the relay is bad and the fan motor needs replaced. I would like any particular instructions on accessing and changing both. MooseMike
    Sr. Mechanic ChevyHD's Avatar
    Jan 2011
    Elberon, Iowa, United States
    On the passenger side at the lower part of the dash there is a huge cover that hides everything. Remove the cover and under the glove box area- you will see a black box with 5-7 wires, that is the resistor. Be sure to inspect the wires and connector. Replace if burnt at all. This was a recall GM issued after many people experienced it. And I've never dealt with anything like your bearing problem.. Good luck.
    Adam
    2004.5 CCSB Duramax
    Max Effort Tuning by Idaho Rob - Goerend Transmission - PCV ReRoute - EGR Blocked - Plugged Resonator - 5" Diamond Eye Turbo Back - Tie Rod Sleeves - All On Mod - Edge Insight CTS - Recon Taillights, Cab Lights, & 3rd Brake Light
    Moved to General Tech. Only completed how-to builds go in the How-To section.
    Christopher
    Last: 02-09-2012, 12:00 PM
  2. Replies: 0
    Last: 01-29-2012, 12:00 PM
    Last: 01-18-2012, 06:10 PM
  4. Replies: 0
    Last: 01-08-2012, 12:00 PM
  5. Replies: 0
    Last: 12-28-2011, 06:00 PM
