    Default 1995 C/K stalls when going into gear with A/C on
    My brothers 1995 Chevy Silverado C/K 1500 stalls going into gear with the A/C on. With A/C off it can go into gear while stumbling as the RPM drops to about 250 before recovering. The load of the A/C just pushes it over the edge.
    In town with A/C on, every time the truck comes to a stop the motor stumbles for a few seconds at low revs, but so far has been able to recover without stalling.
    What could be causing this?
    It is the 5.7L V8 350ci with 127,000miles. It was handed down from dad at about 115,000 miles. Dad is infamous for infrequent oil changes.
    could be a bunch of things... how is vacuum; for starters?
    Sounds like the idle control system is not doing its job. Clean the throttle body really good, including the IAC passages and pintle.
    Good Luck and God Bless
  1. 1995 chevy 1500 no 3rd or 4th gear
    By brendan90zx in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 10-29-2011, 07:25 PM
  2. Replies: 0
    Last Post: 09-02-2011, 05:53 PM
  3. very rough running stalls at stops in gear
    By grip in forum Chevy C/K Truck Forum
    Last Post: 07-25-2011, 09:19 AM
  4. 1995 K2500 4wd low will not shift out of second gear
    By bobm396 in forum GM Powertrain
    Last Post: 11-23-2010, 07:01 AM
  5. Can't Shift into gear!!! 1995 tahoe
    By Jstnwhlr27 in forum GM Powertrain
    Last Post: 05-05-2008, 11:09 AM
