Thread: Abs Problem
    Default Abs Problem
    I have an 05 Tahoe Z71. The problem im having is when im coming to a stop, the abs engages. doesnt do it all the time just randomly, when applying the brakes, not standing on them. Turned the rotors, pads are decent so it shouldnt be them. Changing the hub assy, a few years back, not sure if that is the problem since the sensor is in them. Any help would be greatly appreciated.
    Had a similar problem it was the sensor
    2000 Chevy Silverado 4WD Classic
    2'' lift Torsion Keys and air shocks
    33/12.50 Hankook Dynapro M/T
    3 1/2'' down pipe back 6" Tip
    Dodge Towing Mirrors
    Smoked Tails, Cab Lights, and Side Marker Lights
    1% Rear and Side Window, 20% Front Tint
    American Racing Wheels/ With a custom black paint
    Cold Air Intake
    Edge Performance Chip
    Custom Audio System
    LED Tails
    Black background headlights and parking lights
    Quote Originally Posted by MTM View Post
    were you able to change just the sensor, or did you have to replace the hub assy?
    Quote Originally Posted by nw3dogs View Post
    Hopefully this will help:
    http://www.partsgeek.com/catalog/200...ed_sensor.html
    "Truck Norris"
    - 2008 TX Edition Silverado
    - McGaughy's 4/5 Drop Kit
    - Apline Type R 10s & Amp
    - Airaid CAI
    Nov 2008
    Endicott, NY
    On the earlier model light trucks GM had a corrosion problem where the ABS sensor plugged into the hub. That spot would get rusty and would affect the ABS. There was a recall on the issue. My 03 wasn't involved in the recall but had the same corrosion issue. Since I have stability and traction control Vs just ABS the first thing that starts acting up is the traction control. I will be accelerating away from a traffic light and the Tahoe will suddenly slow down like the brakes are on (they are) and if I lift off the gas pedal TC will shut off and let the truck keep up with traffic. The first time it happened it was covered under warranty but it does seem to happen every two to three years and I have the dealership clean the place where the sensors plug in and the problem goes away.
    Don't know if this issue was resolved by the time the 05's hit the market but it might be worth checking out.
    Bill
    taking a look at it today, hopefully it is just the sensor. thanks for everyone's input.
  1. Odd Problem Help Please
    By gunnar in forum General Chevy & GM Tech Questions
    Last: 07-30-2011, 06:43 AM
  2. HID Problem
    By ..chevy4life.. in forum Lighting Discussion
    Last: 02-10-2011, 12:33 AM
  3. Got a problem what could it be?
    By DarkCherry in forum Chevy Silverado Forum (GMC Sierra)
    Last: 04-01-2010, 12:17 PM
  4. 96 Chevy tahoe problem fuel problem? Need help ASAP!
    By Fear58 in forum General Chevy & GM Tech Questions
    Last: 12-13-2009, 05:38 PM
  5. problem with 350
    By jasontay in forum GM Powertrain
    Last: 05-12-2008, 07:47 PM
