Results 1 to 2 of 2
    Default 1997 G3500 6.5 wont start.
    Pretty new to the diesel world so I am pretty unfamiliar with these types of engines. I hear mostly nothing but bad things about the 6.5, but a family member recently purchased one that was running fine and suddenly died. We have not been able to get it to start since. Engine cranks and cranks but wont turn over. I diagnosed the issue that it was probably not getting any fuel to the injectors and I was correct. I decided to check and see if fuel was being pumped out of the lift pump, and it appears fuel is not reaching that point either. We have almost completely filled the tank, so that it probably not an issue. I have replaced the lift pump and that did not resolve the issue. I am having a hard time figuring out why no fuel is reaching the lift pump. When the pump is running, the fuel line going to it vibrates as well as the lift pump. I figured this might be normal, but I wasnt sure if it was supposed to vibrate this much. The only thing that i can figure is that there is something wrong with the sending unit? Any help would be greatly appreciated.
    93 K1500 5spd 5.7 350
    Holley 670 cfm
    K&N Cold Air
    Hypertech prom
    Custom Exhaust
    Speed pro forged flat tops
    Msd Ignition
    Edelbrock cam
    Sounds like the problem could be the PMD on the Injector pump (common problem on those).... Where did you check for fuel out of the lift pump?
    Joseph
    Airforce Veteran (7 years)
    NRA Life Member
  1. hard start or wont start 305.
    By timhall1787 in forum General Chevy & GM Tech Questions
    Last Post: 09-29-2011, 09:00 AM
  2. 1997 z-71 with 6.5 wont start
    By five.fold in forum GM Diesel & DuraMax
    Last Post: 08-25-2011, 08:10 PM
  3. 03 z71 wont start
    By doughhester in forum General Chevy & GM Tech Questions
    Last Post: 11-01-2010, 04:57 PM
  4. wont start
    By jprimrose4292 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 06-11-2009, 10:56 AM
  5. 1997 Silerado ....5.7 vortec . Wont start when cold
    By qpe05 in forum GM Powertrain
    Last Post: 09-05-2007, 03:22 PM
