Results 1 to 9 of 9
Thread: namron67
    Default namron67
    1995 GMC Sierra 4X4 Carburated, Won't idle, have to pump accelerator to rev. engine. when holding throttle 1/2 open engine acts like it is starving for fuel, installed new fuel filter.
    This is my first post.
    Sr. Engineer
    Oct 2010
    Indianapolis, In
    Welcom to the forum. What carb do you have and can you verify fuel pressure at the carb. Tell us a little more about your set up as it doesn't sound like stock.
    I was completely wrong. It is not a carburetor, it is a 5.7L TBI (Throttle Body injector) I don't have the pressure testing gauge, but I will get one and let you know. Thank you
    Is the Check Engine Light on? Do you have any codes in the PCM?
    Clean up your AIC, its a free fix and many times its the culpret
    Hypertech III, K&N, true dual
    05 17" Silverado rims
    99 LS 1500 5.3 "THE MULE"
    Reg Cab Long Box
    285/75/16E Dunlop Rover M/T
    Hypertech III, K&N, Flowmaster Super 10, no cats
    ___________________________
    Jason
    The fuel pressure barely registered. Tomorrow I will drop the fuel tank. I hope this message gets to you.
    Thank you for your help
    Master Mechanic
    Apr 2009
    Let us know if the new pump fixes the problem!
    2005 Chevy Silverado W/T
    Planned mods not in order
    Sr. Engineer
    Oct 2010
    Indianapolis, In
    Sounds like you're on the right track. I also hope you have or had some help for that tank!
