    Default Where can I find this intake manifold?
    Im looking for a performance intake manifold for my 1995 C1500 4.3l V6. It seems like when I come across intakes for these engines there listed for 1990-1994 or something. I can never seem to find one for a 1995. Its throttle body injected and it says vortec on the valve covers. I know its not true votec injection. But are the heads different from that of a 1994 or older? I've tryed sites like jegs, summit, and edelbrock but no luck. Im just looking for a slightly better one than stock because im going to be rebuilding the heads next month and would like to put something a little better.
    Any ideas?
    Thanks for your time and help all!
    1995 they mave have changed the EGR valve, and it may have seen the start of some OBD2 components (the switch was in 1996 for ALL cars).
    is 1995 direct valve/port injection? or do you still have a throdel body?
    Its a TBI engine.
    Try looking at some Boating websites, the 4.3 is a very popular marine engine and a lot of intake parts cross over, they can be found with injected or carburated systems.
    check this place out: http://www.michiganmotorz.com/intake...32_37_132.html
    They are usually the cheapest for parts for my boat. As soon as the part is labeled as "Marine" the price goes way up
  1. 5.3 intake manifold?
    By matth in forum Performance & Fuel
    Last: 09-01-2011, 10:15 PM
  2. Intake Manifold
    By j-schmizzle in forum General Chevy & GM Tech Questions
    Last: 05-06-2010, 11:29 PM
  3. Intake manifold
    By 206fishman in forum General Chevy & GM Tech Questions
    Last: 11-09-2009, 09:38 PM
  4. need a new intake manifold
    By 81monster in forum Performance & Fuel
    Last: 04-03-2009, 11:35 AM
  5. V8 5.3L Intake Manifold
    By Cleatus82 in forum General Chevy & GM Tech Questions
    Last: 06-12-2008, 10:05 PM
