Thread: 2500 and 2500HD
    Sr. Mechanic
    Jun 2011
    Tuscaloosa, AL
    Default 2500 and 2500HD
    Can anyone tell me what the difference between 2500 6.0 and 2500HD 6.0? I have just the 2500 and my friend has the HD. His sits alot higher than mine. Both have stock suspension
    It depends on the years, The HD has a beefier suspension and bigger brakes. My '11 has a HD towing package including a class V hitch set up. Not sure what else differs, I'm pretty sure the 2500 came first then for marketing GM called it the 2500HD
    2011 GMC Sierra 2500HD SLE 4WD/Z71 Crew Cab Gray Green Metallic 6.0 Gas 6spd Auto 3.73 gears, HD locking rear differential. 18"Alum Wheels (Stock) Stock Michelin LTX AT-II Tires, Banks Monster Exhaust, Westin Platinum SS Oval Step Bars, EGR Window Deflectors, Extang Trifecta Tonneau, Front and back Weathertech Digitech liners. Factory Remote Start with Onstar App on iPhone.
    2003 GMC Envoy SLE Black 4WD 4.2 175,000 Miles all original drivetrain and runs like a champ and no rust or rot!
    Sr. Mechanic
    Jun 2011
    Tuscaloosa, AL
    Yeah I was thinking that about the suspension too. I am wanting to beef it up and maybe add a leaf to the back
    adding a leaf may make your ride bounce more when empty, I'd consider air bags if you need to stabilize heavy loads or when towing. This will allow you to increase or decrease the air in the bags to taylor your ride.
    Your rear end and brakes may be different too, there was another thread about rear ends the other day and an important point was made about beefing up the suspension won't make the rear end heavier duty since the axel, gears, brakes and suspension make up an HD truck. You may want to look at the option of swapping rear axels if you want a heavier duty truck
    I have a 2003 HD. I was shown the different on the frame. Look around the rear wheel at the frame. The 2500 has bolts holding part of the frame together, the HD is solid - one piece.
    Last Post: 11-20-2011, 07:10 PM
  2. Replies: 0
    Last Post: 01-18-2011, 08:50 PM
    Last Post: 08-16-2010, 06:50 PM
  4. Replies: 0
    Last Post: 05-12-2010, 09:30 AM
  5. Replies: 0
    Last Post: 04-11-2010, 04:12 AM
