    Jr. Mechanic b-radical's Avatar
    Nov 2009
    San Diego, California, United States
    Default 4l60 transmission, bad torrent bearings and planetary. upgrade possible?
    My trans is whining on my silverado. My mechanic said its the planetary and posibly the torrent bearings. Any advice? Does anyone know of a super great trans shop in san Diego?
    I would kind of like to take this oppertunity to upgrade my trans. what's the difference between a Allison and dura max trans.? What other options are there? Can it be done on my truck?
    2000 Silverado, 4.8L, LS
    3" Dynomax cat back exhaust
    Drop-in K&N air filter
    200 amp Nations alternator
    KYB GR2 Shocks
    Bluetooth OBD2 adapter with Torque App on Samsung Note 2
    Custom Stereo System l Pioneer/ Boss door Speakers l 1200 watt Performance Teknique amp l 1 farad capacitor l 2 12" kicker comp subwoofers
    Slider rear window l Locking tailgate, de-baged l 265/75/16 Bridgestone Dueler H/L tires l Fully synthetic oil l Tinted windows
    4l65e upgrades - five pinion planetaries l HD sun shell l high performance band
    Quote Originally Posted by b-radical View Post
    The Duramax is a diesel engine, the Allison is the heavy duty transmission that is behind the Duramax. An expensive upgrade. The best upgrade, is the 4L80E transmission.
    I've not heard of torrent bearings??????? The planetary bearings are a weak link in the 4L60E transmission. The heavy duty version of the 4L60E, is the 4L80E, one of the differences , between the transmissions, is the upgraded planetary gears.
    If you want an upgrade, rebuild your 4L60 and upgrade it to a 4L80
    Nov 2009
    right on, thanks Ray.
    Is there a better option of the three I have. (rebuild old trans, put in new trans, or put in rebuilt/refurbished trans)
    What is the avg, mileage most chevy owners get out of there 4l60? I have 136k miles on the truck, I feel like mine went out prematurely, could this be true?
    Sr. Apprentice CowsPatoot's Avatar
    Nov 2010
    Wilkesboro, NC
    Note that you actually have a 4L65e, not a 4L60e...the difference being that the 4L65 has an extra bolt at the top dead center of the bolt pattern (plus some negligible internal changes. That info will be important if you are changing it for another one.
    I was recently in a similar position with my 2001 Z71. Although I do a lot of light duty towing (around 4-5000 lbs) through the mountains, I am otherwise not hard on the transmissions...I was never happy with how short of a life the 4L65e had. Second gear went out in the original at 76,000 miles...paid $1700 for a "reputable" local shop to replace it. Second blew a planetary gear at 89,000 miles (1000 miles past the 12k warranty)...paid a different shop $2500 to build a "heavy duty" transmission for it. That one ate the 3rd gear clutch at 205,000 miles, and I believe I did it right this time. I paid http://www.maddogtransmissions.com $1600 for their "stage 3" build with a new torque converter, and put it in myself. I was VERY happy with this company, and would definitely recommend them. I only have 5k on the new tranny, but it feels far better than any of the others...especially with a heavy load on it. I think it says a lot about their confidence in their product when they put a big "MadDog Transmissions" sticker on the top of the transmission...in a spot that it would only be seen if someone were removing the transmission.
    Check out the videos he has explaining how he fixes the factory weaknesses. Even if you decide to go elsewhere, his videos will help you become a more educated consumer when talking to a local shop.
    On a side note...I got it cheaper than their site's price because I did drive down to their shop to pick it up in person (along with dropping off my core). I chose the stage 2 shifting with a 2300 stall converter.
    Everyone should own a Ford once in their life....how else can you truly appreciate a Chevy?
    Nov 2009
    sweet, thanks cowspatoot. The truck is in the shop now. $1800 total for rebuild with 5 pinion front and rear planetary, heavy duty shell, rebuild kit and something else, I forgot. I trust the shop, my mechanic recommended them. I can't wait to get my truck back.
    Thanks for all the advice.
    Any thoughts on the 5 pinion planetary upgrade from 4 pinion?
    I think the theory is, that the load is now distributed across 5 points instead of 4. Thus, each load point has 20% of the load instead of 25%.
  7. Thanks b-radical thanked for this post
  8. #7
    Nov 2009
    makes sense. Is there another thread for avg transmission life on our trucks?
  1. 4l60-e transmission fluid capacity
    By shilton1986 in forum GM Powertrain
    Last: 02-18-2011, 01:36 PM
  2. What transmission do I have? 4l60 or a 700r
    By lidster777 in forum General Chevy & GM Tech Questions
    Last: 01-24-2011, 10:30 PM
  3. 4L60e Transmission Upgrade?
    By chevytruckman in forum GM Powertrain
    Last: 11-02-2010, 09:46 PM
  4. 4L60 transmission issue
    By mug23 in forum GM Powertrain
    Last: 05-30-2009, 09:23 PM
  5. 4l80 swap to 4l60 transmission
    By homer911 in forum GM Powertrain
    Last: 03-17-2009, 10:15 PM
