    Default Automatic Shift Linkage on 1995 Suburban Sticking in Park
    Every once in awhile my shifter will not shift out of Park. I am about to take a long trip so I don't want to get stranded somewhere because it won't go into gear.
    Can someone confirm for me whether or not the brake pedal must be depressed to shift out of Park? It is a K1500 '95 Suburban. I am wondering if there is a solenoid somewhere that keeps it in Park until the brake is depressed. Maybe that solenoid is sticking and not releasing the linkage? Or maybe the linkage is loose if there is no solenoid present?
    Thanks!
    '95 Chevy Suburban 4x4 LS 5.7L
    I am pretty sure you need to step on the brake before shifting it out of P.
    However, I do recall my kid put the key in my sub and able to shift it out of P while engine was not running (rolled out from my drive way)
    Quote Originally Posted by oldmanstruck View Post
    Thanks, yes I have determined that you have to step on the brake. It appears that if I wait a few seconds longer than normal, it will allow it to come out of park. I suppose a solenoid somewhere is moving slowly, or sticking a little. If I jump in, push the brake, and quickly shift out of Park, then it won't come out. If anyone knows, I would like to know where all this is controlled. I am assuming that sensors detect that the brake is pushed, and then release the shift cable, maybe down around the transmission somewhere?
  1. I can't shift from Park! Please Help!
    By TemperMonkey in forum Chevy Truck Talk & News
    Last Post: 03-31-2012, 10:41 PM
  2. 1995 suburban 454 Automatic Tranny help
    By lovemys10 in forum GM Powertrain
    Last Post: 12-28-2010, 07:43 PM
  3. stuck in park, will not shift from park to drive on 98 taho.
    By jllk in forum Chevy SUV & Crossover Tech Forum
    Last Post: 11-08-2010, 07:44 PM
  4. need Shift linkage removal help for neutral safety switch replacement
    By Samman23 in forum General Chevy & GM Tech Questions
    Last Post: 09-07-2010, 02:06 PM
  5. 99 Suburban Mirror; shift from park
    By 99fxst99 in forum Audio, Video & Gadget Tech
    Last Post: 01-19-2008, 07:51 PM
