Thread: Door panels?
    Default Door panels?
    Need to remove the the drivers side rear panel to access the window lift. Is this a standard poop on panel? Has anyone had a random window failure?
    never mind too simple, didn't see the two 7mm screws.
    How did you make out with the window?
    2009 GMC Sierra 5.3L running on E85
    Black and chrome
    Volant CAI
    Borla dual exhaust
    Chrome Billet grill
    Tonneau cover
    4300k High/Low Beam HIDs
    Westin Ultimate Bull Bar with PIAA 540s
    Blacked-out tail and third brake light
    Quote Originally Posted by Als09Sierra View Post
    I have it all apart, with the window regulator out. I have to wait a day for the new one to come in but it was darn simple two 7 mm screws, lift the panel, undo the lamp and window switch, removed the speaker cover while I was at it to respray it since it had some rust on it. Undo the speaker's 3 ten mm screws and the regulators 2 more 10 mm screws and then removed the motor.
    Has the same Bosch regulators as my BMW's.
    While I'm at it how do I know if it has a Bose system or not? Wouldn't the headunit say Bose on it? It has the subwoofer and OnStar but Crutchfield's site list's
    with bose with onstar
    without bose with OnStar
    without Bose with factory subwoofer
    without Bose without factory subwoofer
    I have OnStar but no sure in the Bose as the speakers have no markings nor does the headunit.
    Quote Originally Posted by M-technik-3 View Post
    What Year-n-Model is your Ride???
    So I've pulled the window lift assembly out and replaced with the new one and still does not work. Was going off what shop owner told me, damn should have done a voltage check prior to purchasing it.
    No voltage when switch is applied in either direction. I see no fuses blown in either panels so any idea what it might be without having to do continuity checks across the circuit?
    My window just broke last week. I was putting it down, Head almost like a "pop" now it won't go down or up the rest of the way (thankfully I have a vent visor, and its only 1/2 inch from the top. If I press the window switch, it sounds like it wants to move, but wont.. I'm guessing maybe it fell of the track or something? I just haven't had time ot pull it apart. Any suggestions?
    00 Chevy Tahoe LT, 5.3 4x4
    Just take it apart and check out what's going on. Only two 7 mm screws holding the panel on. My issue turned out to be no power at the switch so I need to check the circuit.
  1. 99-02 door panels
    By reggiecab2000 in forum General Chevy & GM Tech Questions
    Last Post: 07-23-2012, 12:38 AM
  2. door panels
    By suupasilverado in forum Chevy Truck Accessories
    Last Post: 02-24-2010, 04:23 PM
  3. O.E DOor Panels
    By joshs02ss in forum Chevy Truck Accessories
    Last Post: 01-15-2010, 07:17 PM
  4. door panels
    By 03 Black Sunshine in forum Audio, Video & Gadget Tech
    Last Post: 11-09-2009, 06:08 PM
  5. 92 Door Panels
    By alex16 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 10-03-2007, 01:17 PM
