    Default Stuck passenger side window!!
    I have a 1992 GMC sierra pickup.....350...short bed....auto trans......loaded....
    The passenger window stuck in the halfway position when I attemped to roll it up with the power window button.
    I suppose the motor is shot. I don't want to replace the motor....I just want to get the window UP!!
    What do I do?
    Thanks, Chuckwagon
    window used to stick on old truck I used to drive , hold top of the widow and pull up and push up on the side while pushing the button. Windows on my dads car stuck and mechanic cleaned the connections, sure someone will have an idea to help you
    2012 Silverado
    I tried that.....it won't budge! I took the panel off and all the connections are tight. The old motor is probably just burned out. But I can't get the window to move at all by pushing it up or down.
    Buy a motor and regulator off EBAY they are cheap and you can get it overnight. You should be able to remove the regulator and manually pull the window up and brace it from the bottom.
    What is the "regulator"? Where is it and what does it look like. The motor has what looks like a "braded" fastener.
    If I remove the regulator will the window "move"?
    Thanks! Chuckwagon
  1. Passenger window stuck
    By Iowan1357 in forum Chevy C/K Truck Forum
    Last: 01-30-2012, 10:09 PM
  2. Driver side A/C stuck on hot, passenger side fine-2005 Silverado manual dual temp
    By person197 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 12-04-2011, 05:41 PM
  3. driver's side window stuck open. need help leaving on 2 days for CA
    By loic in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 08-16-2010, 09:10 AM
  4. Rear passenger side window.
    By troyclark in forum Chevy Silverado Forum (GMC Sierra)
    Last: 07-30-2010, 08:12 AM
  5. Passenger side window not working
    By wtlyn72 in forum General Chevy & GM Tech Questions
    Last: 04-04-2009, 06:21 PM
