Results 1 to 10 of 17
    Newbie
    Dec 2010
    Central Oregon Coast Range
    Post No power to rear end
    I have a 1992 Suburban 4x4, 270,000 miles. I think it all started with bad u joints, the drive shaft had been vibrating periodically and then finally the rear one broke and I had to replace it on the side of the road with a hammer which kind of bent the end of the drive shaft where the ujoint go in so the u joint was a bit tight. I found that out from the shop that later rebuilt my tranny. then one day i put it in drive and the rear end went bang and started rattling like there were rocks in it. Long story short. I can put it in drive and it goes nowhere and the rock grinding sounds like its coming from the passenger side rear axle tube. Took the differential cover off and found a few small slivers of metal but i cant see any thing broke. when I turn the rear drive shaft by hand it catches a bit every few revs. I drive it around in four wheel drive and there isnt any sound from the rear at all. Its my beater so as long as it drives...However I've been driving it around like that for about two years and It's probably time to fix it. Any Ideas? And how long do you think I can drive it around in front wheel drive? I have to wait for the 4x4 to engage before I out it in gear at start up other wise it grinds away until the rear drive line stops spinning after I put it back into park.
    I'd say either broke an axle shaft or the spider gears in the diff.... Possible you broke the pinion gear but I'd lean more to the spider gears...
    Joseph
    Airforce Veteran (7 years)
    NRA Life Member
    If not the gears the bearings , allowing the axle shafts to become disengaged
    oldfart2413@gmail.com
    While in park, you should raise one rear wheel at a time and try and spin the wheel.
    If it spins, the axle is broken or the diff spider small shafts are broken. I don't think the gears can get stripped, but I could be wrong.
    When you opened the diff cover, did you inspect the ring gear all the way around?
    1993 964
    1996 318TI
    Quote Originally Posted by bazar01 View Post
    Easiest way to tell, pull the cover (a 5 min job) and inspect the inside of the diff.
    NOTE: before you remove the cover, be sure the fill plug can be removed.
    He said he opened the diff, "Took the differential cover off and found a few small slivers of metal but i cant see any thing broke. when I turn the rear drive shaft by hand it catches a bit every few revs".
    I don't know what he meant by small slivers of metal though. Maybe iron dusts sticking to the magnet? I am beginning to think maybe the ring gear is stripped on some sections that's why it catches every few revs when he turned it by hand.
    I think 5 minutes to open a diff is doable if all the bolts cooperate. You'll never know when a bolt breaks due to rust or siezing.
    If an axle shaft lost it spines would it cause this if it does not have limited slip or a locker?
    Missed it, having one of those days, I guess. Thanks for pointing it out.
    I think your right, but probably can't see the spline without removing the axles. With both wheels in the air, and the cover off, having someone turn each wheel while you hold (without getting hand jammed, maybe using a screwdriver jammed against the cage) the axle pinion gear. If stripped, the axle should feel like it will move in the gear.
    That will do it, you have to lock the diff cage against the case, then turn the wheel. If you can see the axle spin but with the diff locked, the splines are stripped, but if you can't see the axle spin, it is broken in half somewhere in the middle.
    Newbie
    Dec 2010
    I appreciate every one taking the time to respond. i looked in the diff and like i said there were just some small metal slivers. Looked like normal wear and tear to me. It's a corporate ten bolt...stock i guess. The ring gear appeared to be ok as far as not missing any teeth. I'll get out there and pop the back end up this weekend. Currently all of my jacks andtools are tied up in a clutch job on my wifes explorer. Thanks again!
  1. No Power to Rear Seat Audio System
    By Jr. in forum Audio, Video & Gadget Tech
    Last: 03-05-2014, 04:29 PM
  2. Power rear sliding window Help
    By conroe in forum Chevy Silverado Forum (GMC Sierra)
    Last: 03-13-2012, 11:57 PM
  3. Rear power slider for 2009?
    By readgriff in forum Chevy C/K Truck Forum
    Last: 03-05-2012, 08:52 PM
  4. Power Sliding rear window
    By aloxdaddy99 in forum Chevy Truck Accessories
    Last: 06-22-2011, 10:14 PM
  5. 91' Stuck Rear Power Window
    By Ramolap in forum General Chevy & GM Tech Questions
    Last: 04-28-2008, 12:41 PM
