    Default replacing fuel pump on 93 chevy 1500
    My friends dad asked me to help him with replacing his fuel pump on a 93 half ton. He wants to take off the box to get at it. just wondering if anyone has input to help this procedure go smoother and faster. and tips, storys or step by step instructions would be helpful! thanks
    When I replaced my fuel pump 3 freakin times in 3 weeks on my 99 NBS, we (me and 3 others) took the bed off each time.
    All it is *I THINK* is unbolting the fuel filler neck from the bed itself and undoing the 6 bolts I believe (on mine) and lifting up and over the rear tire. From there the fuel pump should be easily accessed.
    Putting it back on is well the reverse. Should go pretty smooth with some willing volunteers maybe 4-6 who are in the 5'10"-6'6" foot height range.
    Current:
    Future:
    The how-to sub-forum is not for requesting how-tos. It's only for completed how-to instructions. Moved to General Tech.
    Christopher
    The box has 8 bolts holding it on...there gonna be tight/rusted it so i would throw some heat to them...take out the tail lights and disconnect them and pull the wires out...then take out the three bolts that hold the fuel filler neck in and push it threw and take out the bolt thats holding the wire/ground on also...you then are ready to take off the box...2-4 guys can do it pretty easy...once you get it off,wash the top of the tank off so you can see it better cuz gravel and dust will be up there...disconnect what you need to and then remove fuel pump...MAKE SURE NO DIRT/CHUNKS GETS INTO THE TANK...Install new pump and hook everything back up and that should do it...ALSO make sure you check the rear brake lines cuz its ALOT easier to fix them with the box off!...check for other issues while the box is off...GOOD LUCK
    Line-X'd Bed
    5.3L Flex Fuel
    275/65R18 Toyo Open Country AT2's
    2" Rough Country Leveling Kit(want to get the 2.5 RC kit)
    EGR In-Channel Vent Visors
    Exterior PLUS Package
    Interior PLUS Package
    K&N Drop-In Air Filter
    ProFlaps
    Cat-Back Dual Exhaust
    Black Bowties
    ProFlaps
    Towing Mirrors
    Next Planned Mods
    Blacked out Tail Lights
    Aftermarket Rims
    X2 of what everyone else has said!! Also just a good idea is to tell him that whichever pump he decides to get make sure it comes with a new a new plug and wires because those plugs at your fuel pump are known to burn up pretty easily, just and easy thing that you might as well replace!
    2006 Duramax LBZ
    Edge Evo
    4'' Diamond eye to 6'' tip
    Lots of work left to do!
  1. Replacing fuel pump on 1993 GMC Suburban, 5.7L, 350 tbi.
    By backcountry horsewoman in forum How-to Guides
    Last: 08-26-2013, 10:40 PM
  2. HELP!!!!Changed fuel pump and ECM. fuel pump still wont turn on
    By fast_stang_88 in forum GM Powertrain
    Last: 06-03-2011, 04:46 AM
  3. New Part FUEL PUMP ELECTRIC Chevrolet Silverado 1500
    Last: 04-10-2011, 06:07 PM
  4. no power to fuel pump 89 1500 4x4
    By eldoark in forum Chevy C/K Truck Forum
    Last: 01-22-2011, 07:40 PM
  5. Replacing the fuel pump
    By blueZ71 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 12-17-2010, 02:55 PM
