    Default Changing out the multi switch on a 1996 Suburban
    Hi, all. Was trying to change out the turn signal/multi-switch on my 1996 GMC Suburban this afternoon, and ran into a small problem. Got the switch loose from the column, got the small cruise control plug loose and got the large plug with the multi-switch and and ignition switch wires loose. But I couldn't get the two long thin parts of the large plug that go to the multi switch out of the large plug body. So I figured I should probably ask someone here who has done this BEFORE I go and break something by getting in a hurry and Oops-ing the situation.
    Any help/suggestions? Thanks.
    Sr. Engineer
    Dec 2011
    11-22-boogie woogie avenue
    Well, that figures. I got the switch installed, checked it out, and I *STILL* have no brake lights and no turn signals. I checked the fuses, changed the bulbs and the tail light boards, but no turn signals and no brake lights. On the positive side, the wipers, headlights and tail lights, and one backup light all work, along with the high/low beams. (No idea about the cruise control yet, as I have no brake lights to be on the road with)
    Any other ideas/suggestions?
    OK; all's well. Bit of friendly advice to anyone else trying this- ALWAYS, ALWAYS double-check that you got the main connector between the multi-switch and the harness seated ALL THE WAY IN. Makes the lights work MUCH better! ;) D'oah!!!
  1. Heater fan switch not changing from defroster to dash vents??
    By miked70 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 01-01-2012, 12:23 PM
  2. Tahoe silverado 1995 1996 1997 blower fan speed switch
    Last: 04-09-2011, 11:20 PM
  3. Multi-function switch
    By stevers in forum Chevy Silverado Forum (GMC Sierra)
    Last: 01-04-2011, 02:25 PM
  4. 2001 Silverado Multi Function Switch / BCM
    By egt1 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 10-15-2009, 07:05 PM
  5. 2001 Silverado Z-71 Multi Function Switch
    By egt1 in forum General Chevy & GM Tech Questions
    Last: 10-15-2009, 07:00 PM
