    Default Another leveling kit question
    I'm looking to level my 2003 1500 z71, no suspension just keys, found a couple kits for about $100 but I have heard good and bad things about the stress it puts on everything. Wondering if it would be better to do a stand alone level or if suspension would be needed too. Not looking to lift it up right now, just to level my front so i sit level. Any input? Also, does anyone know if leveling the front would fit 33's? from my understanding the normal tires are 31's if I'm not mistaken, and I have heard 33's will fit but might rub on the plastic underneath the bumper on the front. Being that I'm not a mathmajician and most of you guys are basically geniouses, could you correct or direct me? Thanks!
    If you can't beat em', Scare em'
    Blue 1996 Chevy 1500 z71 5.7 straight pipes
    First of all I dont know where you heard anything about modifying your suspension, leveling keys only modify the torque on your torsion bars, thus raising the front end of your truck. Quite honestly, the have the Rough Country kit which is the one that I am going to use, it comes with 3" blocks for the rear, 2 keys for the front, and shocks all the way around to help with potential ride quality issues. I have heard nothing but good reviews about this kit as well!! And yes you will be able to fit 33's and as far as I know you won't have to cut plastics or make any further modifications to aviod rubbing. Hope this helps! Take care.
    Nov 2011
    Central Illinois
    If you just want to level the front end then keys are perfect. Make sure to get longer shocks or shock mount extenders. Your factory units don't have enough travel. And make sure to have it aligned.
    I don't know about fitting 33's. Height will be okay unless you do a lot of off roading where you will be looking for full suspension travel. I would be worried about rubbing (inside of tire to miscellaneous suspension component) when you turn all the way to lock. Just something to think about.
    2012 Silverado 1500 LT 4X4
    2003 Suburban LT 2500 6.0L
  1. leveling question
    By SargeZ71 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 02-13-2012, 02:19 PM
  2. And yet another leveling kit question
    By OneWheelWonder in forum Lifted & Offroad Suspension
    Last: 02-06-2011, 10:28 AM
  3. Leveling kit question
    By rideout in forum Lifted & Offroad Suspension
    Last: 07-03-2010, 01:00 PM
  4. Leveling Kit Question
    By VArebel in forum Chevy Silverado Forum (GMC Sierra)
    Last: 03-21-2010, 10:05 AM
  5. leveling kit question
    By rick88122 in forum Lifted & Offroad Suspension
    Last: 12-28-2009, 09:36 PM
