    Default Electrical problem
    My truck started and nothing electrical worked( radio ,windows, a/c).
    Dec 2011
    Jacksonville, FL
    We're definitely gonna need more specifics!!! Year, model, what mods or parts have been changed lately, etc....
    Sorry. It's a 1985 gmc Sierra with a 350 vortec small block. I just bought it. I was having a problem with flickering (headlights, dash lights radio) so I figured out my engine wasn't grounded to the frame. It's worked fine for a couple weeks. Now this. Thanks !
    Dec 2011
    Jacksonville, FL
    I would start by checking grounds. You mentioned it's a vortec so it isn't the original motor, how long hs the motor been in the truck? There are most likely a few wires that couldn't be retrofitted into the '85 that may be causing some of this!
    Not sure how long. Not too long. I notice the wire I used had a little burnt spot on the wire coating. I'm going to get a heavier wire. It's worked perfect since I grounded it. What about fuses?
    Dec 2011
    Jacksonville, FL
    Yea fuses and relays could cause this....just go through all of the fuses and check them.
    Dec 2011
    Jacksonville, FL
    Yea man if that doesn't fix it just let me know.....one of us guys on here can help you figure it out!
    Cool. Do u think that wire that I used might have been the cause? I guess anythings possible
    Nov 2011
    Central Illinois
    Quote Originally Posted by Quietflight72 View Post
    Be careful using heavier wire. If there is a short you could damage components instead of just burning a wire. That's like replacing a 5A fuse with a 10A because you keep blowing the 5A. Not usually a good idea.
    Also, make sure the wire you replaced was not actually supposed to be a piece of fuseable link. Replacing that with a piece of wire is bad.
    2012 Silverado 1500 LT 4X4
    2003 Suburban LT 2500 6.0L
  1. Electrical problem?
    By brunetce in forum Chevy Silverado Forum (GMC Sierra)
    Last: 01-29-2012, 12:24 AM
  2. Electrical Problem
    By Sage in forum GM Electrical Tech
    Last: 12-20-2010, 04:46 PM
  3. Electrical Problem
    By tks20 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 03-07-2010, 09:00 PM
  4. Electrical Problem
    By bldawson89 in forum General Chevy & GM Tech Questions
    Last: 03-06-2010, 07:24 PM
  5. Electrical problem
    By '90_400 in forum Audio, Video & Gadget Tech
    Last: 12-08-2008, 08:53 AM
