    Default Cats plugged??????
    I have some power and hesitation issues on my mule, I am g
    beginning to think the cats are clogged, short of cutting them off are there any tricks that really work for such diagnosis?
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    The best test is doing a back pressure test. This is where you take out the o2 sensor and attach a pressure gauge. you can also measure the temperature of the inlet and outlet of the cat after running it a while. If the front is 400* or more hotter than the back, chances are that it is clogged.
    You can also take out the o2 sensor upstream of the cat and see if you gain any power. It will be loud but it will tell the story!
    Does the power issue continue throughout driving or just when you start out from a stop?
    2000 Chevy Silverado 4WD Classic
    2'' lift Torsion Keys and air shocks
    33/12.50 Hankook Dynapro M/T
    3 1/2'' down pipe back 6" Tip
    Dodge Towing Mirrors
    Smoked Tails, Cab Lights, and Side Marker Lights
    1% Rear and Side Window, 20% Front Tint
    American Racing Wheels/ With a custom black paint
    Cold Air Intake
    Edge Performance Chip
    Custom Audio System
    LED Tails
    Black background headlights and parking lights
    Quote Originally Posted by MTM View Post
    Yes when the cruise is set on the highway it always feels like it is going headfirst into the wind, i still get 17 mpg on the highway even with the bigger tires on, but it just feels like it is always struggling. But I do know that if I put this up against my suburban and raced them and did a passing test my suburban would win hands down even with power and weight disadvantage. The mule also has a new fuel pump, filter, pressure reugaltor and O2 sensors
    I would say plugged cats. Had a similar problem but it was just at start and it ended up being the MAF sensor
  1. Plugged a Bad EGR. What can this cause.
    By Josh in forum Maintenance & Upkeep
    Last: 08-14-2013, 07:30 AM
  2. Plugged Cat???
    By SGSelby in forum Chevy C/K Truck Forum
    Last: 01-30-2012, 01:23 PM
  3. Aftermarket High Flow Cats vs OE Cats... same performance HUh?
    By sstoner911 in forum Performance & Fuel
    Last: 04-06-2011, 06:28 PM
  4. Replies: 0
    Last: 09-24-2010, 12:00 PM
  5. Are You Plugged In? - Wall Street Journal
    By ChevyFan in forum Chevy Volt Forum
    Last: 02-21-2010, 06:20 PM
