Thread: Tire Size Question
08-24-2012, 07:53 AM #1Newbie
- Join Date
- Sep 2006
- Posts
- 9
Tire Size Question
I have a 2005 Z71 4X4 with 265/75R15 tires. I have had great wear and tear on the tires, 178,000 miles and only 1 tire change. My issue is at this tire size there is a very small section of tires and tread types available. I used an online tire calculator and it seems tires sized at 31/10.50X15 are just slightly larger and wider then the original. No more then a 1/4" either way.
Has anyone put this size tire on the stock rims and had any issues or is it a good fit?
Thanks for the help.
08-24-2012, 08:34 AM #2
I haven't seen 15 inch rims in a long time, 16 was the standard for a while. I checked TireRack.com for the size you have and only 8 results came up, which is low.
On the other size I think you are missing a number at the beginning. It looks like there were 2 options from GM for your truck from the factory:
245/75R16 or 265/70R17. There are allot more options at those sizes. Could you take a picture of the tire/rim so we can see the numbers on the tire?
08-24-2012, 08:55 AM #3
The 31s are smaller height wise than the 265/75s. The 265/75s measure up at about 1/4 inch under 32 inches at 35PSI....at least thats what my Coursers come in at.
Current:
1999 GMC Sierra SLT Z71 | 5.3 Vortec | Spectre Cold Air Intake | TransDapt TBS | Hypertech 30005 Tune | 2005 Chevy Tails | Clear No Name Headlights | AWS Bug Shield | 265/75/16 Mastercraft Courser A/T | "Ghetto" painted tailgate | Boss HD Speakers | 2005 Overhead Console | Dual Thrush Turbo Mufflers | Ye Olde Toolbox "borrowed" from ex-brother in law
Future:
3 inch lift kit | 33 inch A/Ts | 4.10 gears | Bigger Alternator | Electric Fans | Oil/Trans Fluid cooler with fan | Custom Tune | Headers | Re-done exhaust | Paint | Interior Restoration/upgrade with newer model stuff | Newer GMC front cap | Window Visors (In channel) | Tint | Low-Profile Tool Box | LEDs throughout stock cab locations | And whatever is spurr of the moment
US Navy Sailor :sign0011:
Tire Size Question
By tazss in forum Wheels & TiresReplies: 4Last Post: 04-02-2012, 08:16 PM -
Tire Size question?
By kingaudis4 in forum Chevy Silverado Forum (GMC Sierra)Replies: 6Last Post: 06-10-2011, 07:39 AM -
Another Tire Size question.
By Corins in forum Wheels & TiresReplies: 0Last Post: 12-29-2009, 07:31 PM -
tire size question
By carrfire in forum Wheels & TiresReplies: 4Last Post: 11-26-2008, 01:12 AM -
06 HD tire size question
By bluedog in forum Chevy Silverado Forum (GMC Sierra)Replies: 4Last Post: 11-06-2008, 11:20 PM
Bookmarks
