Results 11 to 14 of 14
    heres one thing im trying to think real hard on....
    im not sure... BUT...
    im pretty sure this didnt start until right after i got my intake manifold gasket replaced about 3 weeks ago, but the thing is im not sure, of course i was paying extra attention right after the repair to make sure they didnt mess anything up but i can remember if this misifirng was prior to that or not
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
    Yeah, I usually replace injectors around 120K to 140K. Generally makes things work better all around, and prevents failure in other areas.
    Good luck!
    -Skippy
    2006 Vortec Max 1500
    Performance:
    Other:
    -Spray-in Bed Liner
    Hey guys I'm new on here but, I had the same problem with my 98 5.7. The intake and head gaskets were the victim of Dexcool. The intake was leaking antifreeze into the cylinders just enough to dampen the plugs and cause a misfire. Once the engine ran for just a little bit the plugs would clean up and start firing again. I yanked the heads and rebuilt from there on up. Just check the plugs after it has sat for a day or so or start it and let it run for about a minute, shut it off before the miss goes away and then check the plugs and you should be able to find exactly which plugs aren't firing just by the condition of the electrode. Good luck
    I would pull the spark plugs and check how they look. Also, it would be a good idea to determine if the misfire is occurring on 1 or more cylinders, and determine which cylinders are misfiring. You can use a spark tester tool for this. If all else fails, replace your spark plug wires and spark plugs (if you haven't recently) and see how it runs then.
    If all cylinders are firing, but 1 is still misfiring, it may be a faulty injector. In order for the engine to run you must have fire, air, and correct timing.
    As for the Timing, as an engine warms up the timing will advance. Check your timing to make sure it is correct. You may just have to align the distributor or change a timing belt.
    As with anything, test the most likely culprits before trying to replace anything. Replacing parts that may otherwise be good can really add up quick, and just about every mechanical or electrical part can be tested one way or another.
    Good luck!
  1. misfiring help
    By reggiecab2000 in forum General Chevy & GM Tech Questions
    Last: 12-01-2011, 11:24 PM
  2. chevy 350 5.7 in 1500 misfiring
    By chimp54321 in forum General Chevy & GM Tech Questions
    Last: 08-29-2011, 07:08 PM
  3. Misfiring
    By KyleZ71 in forum General Chevy & GM Tech Questions
    Last: 11-12-2010, 10:10 AM
  4. help sputtering stilll here
    By fab_101 in forum Performance & Fuel
    Last: 12-12-2009, 12:05 AM
  5. Misfiring troubleshooting, 86 k10 4x4 silverado 305
    By Daniel in forum Chevy C/K Truck Forum
    Last: 05-29-2008, 10:23 PM
