    Default Water leak at heater hose from bad connector?
    Hi everyone,
    This morning, I noticed a substantial water leak right where the heater hose goes into the firewall on my 2008 Trailblazer (4.2L). It was clear water, not any sort of antifreeze. Anyway, I jiggled the hose a little bit and it seemed to lessen the leak to a degree. My question is whether the consensus would be a that the leak was a connector? I verified that it wasn't the air conditioning evaporator...I haven't run my a/c in about 3 days, which is why I started getting nervous see the water leak. Any help or insight would be appreciated
    Thanks!!
    If the leak is clear water without any coolant and you have coolant in the engine, then it isn't a coolant leak. There are only 2 other ways to get clear water out of your truck... A/C system or rain/water. You might have trash in the cowl stopping rain water from draining properly, causing it to leak out where you are seeing it.
    Thanks, Tom...I just drove to pick up lunch, and realized that I've had the defrost on all morning and the heat controls about 1/4 of the way up. When I parked the truck, it appeared to be bone dry underneath...I'm going to go double-check here in a few minutes. Then it would have to be the a/c since the defroster was on, right?
    I try to be handy and do things myself...it sort of freaked me out that the water didn't appear to be coming from the a/c evaporator drain valve, though.
    Quote Originally Posted by Stratchick View Post
    Yeah... the defrost forces the A/C compressor to run. Hey, the best way to learn is by jumping in and "doing"! That's why we're here to help if you get into a jam. Welcome to the group, by the way.
  1. 98 Suburban- heater hose HUGE LEAK-can I clamp or bypass it?
    By phoebeisis in forum General Chevy & GM Tech Questions
    Last: 08-04-2011, 06:20 AM
  2. How to remove airbox 1998 Suburban 5.7?? to get at heater line connector
    Last: 08-01-2011, 01:44 PM
  3. Wiring Connector From Hell on Heater/AC
    By arby in forum General Chevy & GM Tech Questions
    Last: 06-28-2010, 07:51 AM
  4. Heater hose routing
    By foxden in forum General Chevy & GM Tech Questions
    Last: 12-11-2009, 02:19 PM
  5. Heater Hose
    By cliffwilson in forum The Coffee Shop ~ Chit Chat
    Last: 10-13-2005, 03:59 PM
