    Default replacement Driveshaft Center Bearing quality???
    Any one have any thoughts on the aftermarket driveshaft center bearings you can get from the parts stores? I found one for like $25 at advance auto but it wasn't a factory replacement. It was about $60 cheaper than the other one they had that looked identical to the factory one that went bad on the truck... Are the cheaper ones junk??? Does it matter???
    Theres at least 30 companies that sell replacement carrier bearings, who knows how many of them are from the same manufacturer and rebranded for sale.
    There hasnt been any one brand thats had a lot of complaints, most of them offer a limited warranty, this is one of those items that you take your chances with, it could last 3 days or it could last 30 years no way head of time to tell what it's gonna do.
    I've been searching for years for a company that makes one with a zert fitting so it can serviced, unfortunately manufacturers have gone to service free bearings. Funny on older trucks (pre 80's) the manufacturer thought it was a good idea to lube these and had had a zert fitting on them.
    yeah, i caved and went expensive... the housing looked quite a bit tougher and it appeared to be a direct replacment although they both had the same warranty. Who knows. I probably got suckered in on this one.
    You'll never know and after a while it wont matter, the real proof is as long as the part last's and doesnt fail leaving you stranded somewhere, if it can do that it was money well spent.
  1. Lower Steering Column Bearing Replacement
    By ippielb in forum Maintenance & Upkeep
    Last: 07-06-2012, 09:01 PM
  2. Center console/ seat replacement? No foldable center console...
    By seanobryant in forum Chevy Silverado Forum (GMC Sierra)
    Last: 11-06-2011, 11:44 PM
  3. Wheel bearing/Hub assembly replacement - front
    By mike04rr in forum How-to Guides
    Last: 10-29-2011, 06:06 PM
  4. Center support bearing symptoms when bad
    By Jaceracer in forum GM Powertrain
    Last: 08-12-2011, 09:07 AM
  5. how to get replacement center caps?
    By 383man in forum Lifted & Offroad Suspension
    Last: 06-21-2009, 08:49 AM
