    Default Radio connection ?
    Hello, I recently bought a 2000 Silverado and Am planning on putting an aftermarket radio in it. I pulled the radio and noticed two connectors instead of the one that I have seen before. What does this "extra" connection do, and can I leave it unplugged with no problems? There is the one stock connection that I have seen before and another one on the left of the radio. Is this for the security or what? Thanks, Jordan.
    Jr. Mechanic Patman's Avatar
    Nov 2010
    Saskatoon, Saskatchewan
    can you take a picture of the connectors... as i recall in my 99 nbs i only had 1 connector... could you be referring to the antenna plug... if so you will need that one plugged in. so yeah post a pic and im pretty sure i can let you know what it is.
    2006 CHEVROLET SILVERADO LT
    - STOCK FOR NOW, PLANS - LEVELING/LIFT, FUEL WHEELS AND BIGGER TIRES
    NEW
    OLD
ID:	43781it looks like this.. Icould not get a good pic of it in the dash.
    One is for the antenna, the other is the electrical connections.
    I am only talking about the black connection. Can it be left unplugged? I checked, the new radio works without it plugged in. If so can I tape it off?
    Nov 2010
    thats the connector for the factory cassette player that is usually placed in the center console... it is unused un less you have the cassette. who even has cassettes anymore?? hope i could help.
    Thanks Patman, what should I do with the connector as the new radio does not use the connection. Electrical tape around it?
    What is a tape deck? Electrical tape should be fine. the pins are actually on the radio side, so as long as nothing gets stuck on the plug on the wire side, you should be good.
    (I actually have a turn table that I still use) Not in the truck though.
  1. ipod to radio connection
    By aloxdaddy99 in forum Audio, Video & Gadget Tech
    Last: 04-03-2011, 11:42 PM
  2. iPod, iPad, Android phone Connection for Chevy Radio
    By Megasaurus in forum Audio, Video & Gadget Tech
    Last: 01-22-2011, 12:25 PM
  3. Radiator Connection Leak
    By F E Knucklebuster in forum Chevy Silverado Forum (GMC Sierra)
    Last: 12-12-2010, 08:54 PM
  4. Connection under Seat
    By troyb in forum Chevy Silverado Forum (GMC Sierra)
    Last: 08-31-2010, 10:03 PM
  5. Timing and AC connection?
    By m.gauthier in forum Chevy C/K Truck Forum
    Last: 10-01-2009, 10:46 PM
