Thread: Truck dies
    Default Truck dies
    My truck dies when i get to a stop sign. When i have the thermostat in the truck it always dies at stop signs. But when I dont have it in and after it heats up a little it will rev up and stay alive but it seems like a high idle. I have a brand new iac. new spark plug/ wires, distributor, the ignition control module has been test at autozone it was said to be good. any ideas?? its a 91 gmc 1500 4.3l 2wd
    I do not know why the thermostat would cause that issue. I have seen trucks with low transfluid die when stopped. I added fluid to get it to the correct level and the truck ran fine.
    Lack of a thermostat keeps it from getting to operating temp, and therefore the truck stays in open loop mode, running from pre-programmed tables in the computer. Check for vacuum leaks. Those can cause problems!
    I knew that it would not get to operating temp, but did not even think about the open loop mode. Thanks @moogvo
    I figured out today my egr valve wasent working because the tube wasent tight enough so i fixed that. It only moves a little bit is that what its suppose to do. I sprayed so carbon cleaner on the egr and the truck reved up a little does that mean the egr valve gasket is bad? When take the tube off the mass air flow sensor it idles good... is that because of a vacuum leak?
    Quote Originally Posted by djback View Post
ID:	43837 does anyone know where this purple wire goes... its up by the firewall...
  1. Truck starts but dies a few times before it'll stay running
    By MidgeP8 in forum Chevy C/K Truck Forum
    Last: 12-05-2011, 02:17 PM
  2. Truck Almost Dies And Weird Things Happening Please Help Me
    By cappyd892 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 07-21-2010, 12:20 AM
  3. truck starts then a sec later dies...
    By Jcloud in forum General Chevy & GM Tech Questions
    Last: 07-08-2010, 06:03 PM
  4. Truck dies when I turn on my headlights!
    By Big6ft6 in forum GM Electrical Tech
    Last: 12-16-2009, 08:30 AM
  5. Truck just dies
    By bigrig1703 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 08-01-2009, 11:35 AM
