Results 1 to 2 of 2
    Default Service 4WD Warning ~ 2001 Suburban
    The message center (dashboard warning) displays SERVICE 4WD on my 2001 Suburban 1500. I do not hear anything unusual to cause the light. I do not know what to check. Please help.
    I had the same warning come up on my 03 Yukon Xl. I crawled under the truck and started unplugging and replugging in connectors. Luckily, that fixed it. The connector to the encoder motor was corroded. I would start by trying that. Are the lights on your 4x4 indicator on or all off? Unfortunately, most cheap scan tools can not check the codes associated with the 4x4 system, so a Tech II is needed to tell you exactly what the issue may be. You might be able to find a shop near you that has one or a snapon model that can read your codes cheaper than what a dealer would charge. I believe that the 00-06 models have known issues with the encoder motor going bad. But, before you throw parts at it I would have it scanned.
    Last: 09-13-2012, 12:30 PM
  2. Airbag service warning light
    By NCDaywalker in forum GM Electrical Tech
    Last: 01-10-2011, 06:38 AM
  3. 2001 suburban warning bell continues after key is pulled.
    By junktrux in forum Chevy SUV & Crossover Tech Forum
    Last: 10-28-2010, 09:54 PM
  4. Service trailer brake system warning..
    By Punchy0 in forum Lifted & Offroad Suspension
    Last: 10-01-2010, 02:39 PM
  5. 2001 Silverado ABS Warning Light
    By castaves in forum GM Powertrain
    Last: 09-05-2008, 10:46 AM
