Page 1 of 3 123 LastLast
Results 1 to 10 of 28
    Jr. Mechanic Swatchvy's Avatar
    Feb 2009
    Central New York
    Default 2012 silverado engine and tranny issues?
    Does anyone else out there with a brand new 1500 have any issues with the 5.3 mated with the 6 speed transmission? The transmission shifts erraticly, clunks going in and out of gear, and the engine chatters on take off, runs rougher than hell I can watch the tach float all over at an intersection and while maintaining speed, and it acts like it wants to stall. Just curious because the dealer told me that's how all new trucks are supposed to be. I know that's not true but I would love feedback. Oh, it's only got 2800 miles on it.
    Andy
    05 Silverado 1500 Z71 Until 6/5/12
    Straight Pipe Dual Exhaust
    LED Third Brake Light
    Ram Air Cowl Induction Hood
    Edelbrock Shorty Headers
    DeBadged
    Well searching for a gear is common for the six speed learned that after renting a 2012 Suburban in Las Veges on the free way at 75-80 it was constantly trying to decide whether to be in 5th or 6th this was on a total flat in the desert. That's why the tach is fluxing at speed not sure about why it is at idle. I got nothing for the chattering well at rest might be one of the new AFM(active fuel management systems that is trying to save gas. If you have another dealer near by that's not the one that keeps saying its normal ask them. No matter what may be the issue the truck is under warranty.
    Feb 2009
    Central New York
    Chattering coencides with power loss at acceleration, acts like it wants to stall. Gear searching did enter my mind seeing as it mainly does it under 45 mph through towns and villages, unfortunately that only explains the erratic shifting. Thanks for the input, it certainly helps.
    Is there any code being thrown? Also I say bring it to another GM shop the one you bought it from may not help you but another should, if they don't either contact independent shop. I really can't think of anything that could cause this under normal conditions with out throwing a code or some thing being mechanically wrong.
    Feb 2009
    Central New York
    Yea I took it to the dealer yesterday they put 30 miles on it and said it would not duplicate the Problem, hooked up a scanner, it threw no codes and they were done. I got it to duplicate leaving the parking lot. I know a few people with the same power train and they are all baffled.
    Yah that makes me feel like they are lying... Try shifting manually see if it helps or use the tow haul mode just to experiment.
    Feb 2009
    Central New York
    Might help, thanks for the idea.
    If they say all the new trucks are like that then get in another new one on the lot and take the service adviser for a ride. See if it is the same. Does it have traction control? That might explain the loss of power on accel with the chattering. Thats exactly what my wifes care with tc does.
    Feb 2009
    Central New York
    Tc is off and I drove a couple new ones and I know for a fact those ran differently.
    Mine works as expected, smooth, no chatter, no gear hunting. That is exactly what I was going to suggest, good call Pikey
  1. 98 Silverado engine and tranny
    By chevytrucknutzo in forum GM Powertrain
    Last Post: 07-20-2012, 11:37 PM
  2. 02 2500 tranny issues
    By BCCC in forum GM Powertrain
    Last Post: 09-19-2011, 06:14 PM
  3. Tranny Issues
    By TreeMan in forum GM Powertrain
    Last Post: 03-24-2010, 07:36 PM
  4. Silverado engine or tranny problem?
    By Silver1 in forum GM Powertrain
    Last Post: 09-14-2009, 05:28 PM
  5. tranny issues
    By 1994 suburban in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 04-12-2009, 12:51 PM
