    Default 91 c1500 5.7L idle ok hesitates when in R or D with brake applied
    hello, New to this forum. i got 91 silverado 1500 with 5.7 issue im having is the engine stumbles a little whenever it is in R or D. At idle in Park or N the engine runs smooth no signs of hesitation. No code and /or light on. First found IAC valve getting stuck replaced it. issue got better but still there. checked MAp-ok Knock sensor-ok 02 sensor-new with a nice wavefor at idle. temp sensor-new, TPS- ok smooth wake form, new plugs and cap n rotor.....
    ONe thing i notice is that when i spray brake cleanner in the intake manifold gasket area, the 02 tends to pick up that extra fuel that i'am sprying. Any ideas or commomng problems anyone has gone through?? Thank you.
    If you are spraying carb cleaner on the intake gasket and the rpms are going up then it sounds like you have an intake manifold leak. You just have to be sure that none of the spray from the carb cleaner is getting into the Throttle body. If you are sure that it is not, then I would definitely say you have an intake leak. That may not be causing your issue, but it is a place to start.
    Thanks for replying, yes im 100% sure the gasket is leaking and yeah im not 100% conviced that is the main issue but know i need to get rid of any air leaks first. i should have it off in the next 10 mins thanks again.
    Habe you checked your trans fluid? I have seen trucks with low fluid cause stalling and rough idle when put in gear.
    You know what, that never crossed my mind. Definitely will look into that. Thanks!
  1. idle problems with 1991 c1500
    By robbie in forum Chevy Truck Tech Forum
    Last: 09-07-2012, 01:24 PM
  2. '95 C1500 4.3 Hesitates after warming up
    By Sirwriter in forum Chevy C/K Truck Forum
    Last: 05-28-2012, 01:31 PM
  3. 95 C1500 starts then dies and hesitates while driving
    By Kinko in forum General Chevy & GM Tech Questions
    Last: 08-09-2010, 09:57 AM
  4. 95 C1500 Idle problems
    By liquidmetal in forum GM Powertrain
    Last: 01-24-2010, 01:35 PM
  5. 99 c1500 5.7 suburban missing at idle when hot
    By i_build in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 10-22-2009, 06:08 PM
