Results 11 to 17 of 17
    That is a good question. My 02 2 wheel drive used a rack and pinion. My dads avalanche has a gear box. I guess @SurrealOne can tell us if he has a gear box or not as he has a truck.
    May 2011
    Clear Lake, IA
    @Pikey that new one you got with the 4 bolts, do you happen to know the brand of it or where I could get it? All the ones I come across seem to be 3 bolt remanufactured. Or if they are 4 bolt then it calls for the off road package or the luxury package and I have neither. Just standard 4x4 package on mine. Unless the 4 bolt fits either way and doesn't matter then no big deal maybe??
    The warranty company got it at autozone. The 3 bolt reman should be fine as the valve should be replaved during the reman process. I will try to post more about it tonight.
    I checked mine and it looks like it's a 680, as it has 4 bolts. So much for the 670 being the cause of the moaning during low speed left-hand turns?
    Well, my gearbox was replaced and the noise stopped!
    May 2011
    Clear Lake, IA
    @Pikey good to hear it fixed your problem, so youre saying that you had the 3 bolt before and you replaced it with the 4 bolt and everything works fine?
    Yes, I had the 3 bolt and a 4 bolt was installed, the noise completely went away!
  1. steering shaft
    By Harold Swanson in forum Member Introductions
    Last Post: 01-05-2012, 10:09 AM
  2. Intermediate Steering Shaft problem in 2010HD?
    By ajk242 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 03-17-2011, 04:56 PM
  3. Intermediate Steering Shaft
    By Big_Ben in forum General Chevy & GM Tech Questions
    Last Post: 03-29-2010, 01:15 AM
  4. steering shaft
    By loridinnx2000 in forum GM Powertrain
    Last Post: 07-31-2007, 10:20 AM
  5. Intermediate Steering Shaft
    By ukrkoz in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 07-01-2007, 01:42 PM
