    Default 1990 Suburban 5.7 l EFI, stalls when shifted to drive and rev.
    This might be one of those "since yous". Since I had to replace a bad ignition coil, I also replaced the ignition module, dist. cap and rotor, wires and plugs. Set the timing to 0 deg TDC as prescribed,but the truck stalls when shifted to Drive or Rev. Tried advancing the timing slightly, but no help. It has never done this before and I think I may have disturbed something to cause this. Also noticed a chattering of the injectors that I do not believe was there before. inspected vacuum lines, but saw nothing apparent. Any Ideas?
    Are you getting any check engine light? Does it run smooth before you put it in gear?
    no lite. I disconnected the idle air sensor while it was running, no difference. shut it off read the sensor with a meter, it was good. pulled it and sprayed the inlet, re installed, but left it unplugged. it started and had a high idle, but went into drive and rev with no stall. drove it, no stall. I haven't plugged the sensor back in to see if it reverts back to being stupid,ing and it is running,, any ideas?
  1. 1990 C1500 Stalls
    By cmlindauer in forum GM Powertrain
    Last: 05-19-2012, 08:59 PM
  2. Replies: 8
    Last: 05-14-2012, 04:34 PM
    Last: 03-03-2012, 07:00 PM
  4. 87 Suburban stalls when......
    By burbanguy in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 05-07-2009, 01:49 PM
  5. TBI starts then stalls, gas held slowly stalls
    By TigerZ in forum Chevy C/K Truck Forum
    Last: 09-02-2008, 02:27 PM
