    Default Speedometer adjustment
    How can I adjust my speedometer to compensate for tires that are larger than my factory size. Is this a dealer thing or can i do it myself?
    I'm unsure how this sort of thing is handled on pre-99 trucks, but on 99 and later models the truck's computer has to be programmed for the overall diameter of the tires. Either go to the dealership and pay them to do it or buy a handheld programmer and use it to do it.
    Be advised that the computer is finicky about certain tires sizes and will turn on the ABS idiot light if it doesn't like a size you've set with a handheld programmer. (My tires are technically 34.3" in diameter, so 34.5" would have been a logical setting and it tossed the ABS light ... but it was perfectly happy with 34" as the setting, so that's what I used.)
    either a programmer or superlift used to sell a speedometer calibrator (which is what I have). It is hard wired in and you can switch between 2 sizes with a switch as well as fine tune it if you notice it is still off a little.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    That's another approach. What'd that run, @dsfloyd? I ask because if I were going to sink cash into something I'd want it to do more than just the speedo adjustment ... unless it was super cheap. Programmers run in the multiple hundreds of dollars but do all sorts of things. What'd the speedo calibrator set you back?
    A speedo recalibrator plus OBD II code reader would be a worthwhile investment. I'll probably put over-sized tires on every truck I own so it would be a good thing to have handy.
    As for my truck, it came stock with 245-75-16s and I currently have 265-75-16s it. I have driven past enough of those speed limit signs that show you your speed to know that my truck is actually going 2 mph more than what the speedo says.
    You trust what the government tells you (even by way of machines it owns)??? Shame on you!
    Touche! I shall get my speedo adjusted, post haste!
    Sorry surrealone that it took so long to get back to your question. I think it was about $215(correction from previously posted price). I will see if they even still sell it.
    Quote Originally Posted by dsfloyd View Post
    Sorry surrealone that it took so long to get back to your question. I think it was about $100. I will see if they even still sell it.
    No worries, I didn't need the data. It was more for comparative use by those considering a programmer versus a device that just adjusts the speedo...
    Ok I just looked around to see the price and it varys from $210-$240 so disregard the earlier price posted, the ABS light correction (for 4.56 and above gears) is what runs around $100.
  1. Lumbar Adjustment
    By Cjdenz in forum General Chevy & GM Tech Questions
    Last: 12-08-2011, 08:09 PM
  2. tpms adjustment
    By SOAP2500HD in forum Lifted & Offroad Suspension
    Last: 12-30-2009, 08:15 PM
  3. torsion bar adjustment
    By badbowtie12 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 03-25-2009, 03:18 PM
  4. tie rod adjustment
    By skipbeau3790 in forum Member Introductions
    Last: 11-02-2008, 10:36 AM
  5. Fender Adjustment
    By Trex in forum Chevy Colorado Forum (GMC Canyon)
    Last: 05-12-2008, 03:48 PM
