Results 1 to 2 of 2
Thread: 94 burb trans ?
    Default 94 burb trans ?
    Alright hi all i just have to see if anyone else has had this same bad luck. I lost the 2-4 band in my trans pulled the trans took it to a shop paid him to rebuild it. Once i got it back i put it back in than i had all gears but i had to manually shift all gears. I called him up drop off he said it should be a 10 min fix. well with me working so much a couple of days turned in a few weeks maybe even a month or two with no word from him i called him up he said that he looked at it and it would caost just as much money as a paid him to rebuild it. Now i am hot mad i told him i was coming to get my truck after i picked it up (and he stole my battery) i only had 2nd gear and park now the vechile has sat for about 9 month to a 1 only moving it when needed and on day boom i have reverse. Than a month later i have all gears back again but i have to manually shift again. I have not done anything with this but move it not far maybe drive it a mile or so just to keep fluids moving. I just cant get a concept of why only one gear than the others came back any thoughts or experiance with this thank you Jay
    my 88 is doing the same thing and I still try to figure out what to do.
    Sounds like a bad rebuild? Is it from a shop? I did check out my local craigslist and see if I can find a good rebuilder, no luck. Also worry about someone/shop will take everything apart and come back with "higher" price.
    I might want to have someone else check it for you. Good luck
    In my case, I just spoke with a local shop which said $1600 to rebuild and install
  1. Trans Go Jr. Allison 1000 for 6 speed trans 2005-2007
    By 66impala in forum General Classifieds
    Last: 04-04-2012, 01:33 AM
  2. 97 burb trans quit working
    By somonenew1994 in forum GM Powertrain
    Last: 08-18-2010, 07:56 PM
  3. Replies: 9
    Last: 08-05-2010, 01:52 PM
  4. Trans fluid/filter change '02 Burb
    By IrishBrewer in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 08-06-2008, 12:07 PM
  5. `Burb trans question
    By bannedleader in forum GM Powertrain
    Last: 06-10-2008, 10:25 AM
