Chevy Truck Parts on eBay
Chevy Truck Forum - GMTruckClub.com » Tech Discussions » Appearance & Aftermarket » Fog Light Question
Reply
Thread Tools Display Modes
Old 10-30-2009, 05:13 PM   #1
CornhuskerChevy
Sr. Apprentice
Points: 584, Level: 11 Points: 584, Level: 11 Points: 584, Level: 11
Activity: 2% Activity: 2% Activity: 2%
CornhuskerChevy is a glorious beacon of light
Default Fog Light Question
After searching on some other forums for mod ideas, I came across one that seems relatively simple...just double checking before I go into it. One guy said that he put factory high beam bulbs in his fog lights for extra light. Has anyone tried this or will it even work for sure? I do not want electrical problems!
__________________
2007 Silverado Z71
2LT Premium Cloth
Ebony Interior
5.3L Vortec
Factory Running Boards
Big Tex Grille Guard
Delta Pro Tool Box
Spray-In Bed Liner
2.25" ReadyLift Leveling Kit
Plans For The Future...
Larger Tires
Dual Exhaust
Cold Air Intake
CornhuskerChevy is offline   Reply With Quote
Old 10-30-2009, 06:38 PM   #2
TRPLXL2
The Crow
Points: 5,716, Level: 48 Points: 5,716, Level: 48 Points: 5,716, Level: 48
Activity: 100% Activity: 100% Activity: 100%
TRPLXL2's Avatar
Status:
TRPLXL2 is a splendid one to behold
I know which article you are talking about, as I saw the exact same thing the other day. I would say that is a hit or miss thing, the main concern would be wattage? I don't know anything about the NNBS trucks, but most high beam bulbs for the newer trucks are 60 watts. If the fog light bulbs are rated at that or higher than you would be fine, BUT if the fog lights are only rated at say 50 watts even though it's not that much difference you are still taking a chance. I thought on the NNBS trucks the fog lights have the 5202 bulb, so how did he get a different base bulb to fit unless he changed the base. Another thing you have to worry about is heat, that is a small housing which happens to be plastic and I have seen them melt before.
I had a set of H1 bulbs in both my high beams and low beams in my last truck, and I upgraded to a high temperature socket and I also had to shave down the base to make it fit. They worked for as long as I had the truck with no problems, if there is a will there's a way!
__________________
2005 2500HD 6.0/4L60E/2wd/ Completely stock...........for now.
TRPLXL2 is offline   Reply With Quote
Old 11-03-2009, 03:31 AM   #3
Triton911BJ
Jr. Apprentice
Points: 300, Level: 5 Points: 300, Level: 5 Points: 300, Level: 5
Activity: 10% Activity: 10% Activity: 10%
Triton911BJ is a glorious beacon of light
i have a set of my high beam bulbs in my fog lights, so far i have had no problems. i have set my trk up so that when my high beams are on my, low beams/drls and fogs stay on. i have yet to have an issue
BJ
__________________
2005 Silverado Z71 Vortec 5.3L
Tunkhannock,PA
Firefighter/Engineer
Ambulance Driver
Triton911BJ is offline   Reply With Quote
Old 11-03-2009, 09:24 PM   #4
mills
Newbie
Points: 164, Level: 3 Points: 164, Level: 3 Points: 164, Level: 3
Activity: 0% Activity: 0% Activity: 0%
mills is a glorious beacon of light
Can I ask how you hot wired the fog switch to work like that? I hate having to turn my fogs on every time i get in the thing. Thanks for your help in advance......
mills is offline   Reply With Quote
Old 11-03-2009, 10:23 PM   #5
TritonBoulder47
Sr. Mechanic
Points: 459, Level: 9 Points: 459, Level: 9 Points: 459, Level: 9
TritonBoulder47's Avatar
TritonBoulder47 is a glorious beacon of light
Quote:
It's easy... Just a couple of diodes... I'm actually the one that did it to BJ's truck... I did it to my Avalanche as well...
Here's a link to the Avalanche forum page that I used...
http://www.chevyavalanchefanclub.com...c,60928.0.html
It's a really good write-up, plus there is a link for a PDF file too... Very easy to follow step-by-step...
__________________
Tim a.k.a. Da' Boulder
2003 Chevrolet Avalanche Z71 - Emergency Response POV
Firefighter, Fire Policeman, Ambulance Driver, Rescue Tech, Emergency Lighting Installer
Tint, 20's, Bull Bar, Intake, Exhaust, Billet Grill, Stereo, Custom Console, Emergency Equipment, and the list goes on...
TritonBoulder47 is offline   Reply With Quote
Old 11-05-2009, 09:04 PM   #6
Padre
Sr. Apprentice
Points: 1,833, Level: 25 Points: 1,833, Level: 25 Points: 1,833, Level: 25
Activity: 23% Activity: 23% Activity: 23%
Padre's Avatar
Status:
Padre is a glorious beacon of light
Do you know of any instructions for 2007+, or specifically, 2009? Thanks!
__________________
Padre (Chip)
When the power of love overcomes the love of power, the world will know peace -- Jimi Hendrix
2009 Silverado 2500HD Extended Cab, long bed, Blue Granite
Truxedo Duece / Kenwood 9140 / Eclipse amp / Alpine Speakers / 12" sub / 2" lift / Boss 8' Super Duty plow / reverse and forward cameras / Billet fuel door / Plasmaglow Fire and Ice / custom painted pinstriping / custom roof marker lamps / led tail lights / Firestone rear Air Bags, front Air Shocks w/Airlift in cab control / custom canine covers / 2 swing case toolboxes / Hoppy Easylift / 3rd brakelight chrome cover /
Padre is offline   Reply With Quote
Old 11-05-2009, 11:28 PM   #7
dsrtne1
Sr. Engineer
Points: 1,647, Level: 23 Points: 1,647, Level: 23 Points: 1,647, Level: 23
Activity: 11% Activity: 11% Activity: 11%
dsrtne1's Avatar
dsrtne1 is a glorious beacon of light
Very nice, now i want to do all 5 diodes!
__________________
Michael, 16, Corona, CA
2005 Silverado - See my album for my mod list
dsrtne1 is offline   Reply With Quote
Old 11-06-2009, 12:31 AM   #8
TritonBoulder47
Sr. Mechanic
Quote:
Sure... Here's what's on the Avalanche forum...
2007/2008 FTDRL
I've only done it on my '03 Avalanche, BJ's '05 Silverado, and my buddies '05 2500... I haven't gotten to work on anything newer, and I can't find anything on the Av site...
__________________
Old 11-16-2009, 05:48 PM   #9
egreg
Jr. Apprentice
Points: 473, Level: 9 Points: 473, Level: 9 Points: 473, Level: 9
egreg is a glorious beacon of light
I did this mod today on my 2000 Silverado. I have the DRL's working with my high/lows, but I can't find a relay in the electrical center for the high/low beams. I only have one relay, HDLP, instead of one for HDLP-HI and one for HDLP-LO. Here is a pic of the diagram for my electrical center:
Any suggestions on how I can get the fogs, DRL's, and high beams at the same time?
Click image for larger version
egreg is offline   Reply With Quote
Old 11-16-2009, 10:47 PM   #10
TritonBoulder47
Sr. Mechanic
Have you checked the electrical center inside the truck...? maybe they are there... I'm not sure about the newer trucks...
__________________
Reply
Bookmarks
Tags
light, question
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
vBulletin Skin by CompletevB
Copyright 2004 - 2008 GMTruckClub.com - This site is for entertainment purposes only
Ad Management by RedTyger
