Chevy Truck Parts on eBay
Chevy Truck Forum - GMTruckClub.com » GM Truck and SUV Forums » Chevy SUV Forum » Chevy Tahoe / GMC Yukon » new Tahoe Owner has question - 2005-
Reply
Thread Tools Display Modes
Old 11-02-2009, 10:07 AM   #1
remist17
Jr. Apprentice
Points: 600, Level: 11 Points: 600, Level: 11 Points: 600, Level: 11
Activity: 13% Activity: 13% Activity: 13%
remist17 is a glorious beacon of light
Default new Tahoe Owner has question - 2005-
Well just purchased a 2005 LS Tahoe 4x4, 5.3 Air Ride, 4.10 limited slip all wheel drive with 43,000 miles. I have never owned a 5.3 or this new of a SUV. Can you tell me somethings to watch out for or were to get a good repair manual.
The truck is fully loaded power everything, DVD player, 6 CD changer, blah blah blah....
Hows the tranny's and transfer cases? Normal surface intervals of 60K?
Can someone let me know the fluid thats required for the Tahoe:
- Coolant
- Transfer Case
- Tranny
- Front and Rear Diff
I am assuming this would be all in the owners manual , but for somereason no owners manual came with the truck !
ADDING PHOTOS 11/9/09 -
Thanks
Paid enough for it and dont want to screw it up !
remist17 is offline   Reply With Quote
Old 11-02-2009, 01:33 PM   #2
Tommygunz
Sr. Apprentice
Points: 152, Level: 3 Points: 152, Level: 3 Points: 152, Level: 3
Activity: 20% Activity: 20% Activity: 20%
Tommygunz's Avatar
Tommygunz is a glorious beacon of light
Congrats on the purchase.. I just got mine as well so I cannot tell you what to look out for
__________________
-2007 Ram 2500 QC 5.9 CTD
-2008 Taho LT1
"There aren't any problems in the world that can't be solved with the proper application of plastic explosives."
Tommygunz is offline   Reply With Quote
Old 11-02-2009, 03:36 PM   #3
unplugged
Legend
Points: 11,085, Level: 69 Points: 11,085, Level: 69 Points: 11,085, Level: 69
Activity: 100% Activity: 100% Activity: 100%
unplugged's Avatar
Status:
unplugged has a brilliant future
Take good care of your Chevy and your Chevy will take good care of you.
If you want a factory manual: http://www.helminc.com/helm/homepage.asp?r=
__________________
There is no way to happiness....happiness is the way.
http://kx6ijq.blu.livefilestore.com/y1pcOFVNH4ix1hjyGUVyXK5LRfef7qSeWzlZDorpQhIEfkZ2ZA  _vXMYypuKMJFw671uF2ZPhjez_j-atRmcjM2zQKpQi1JSsB75/burb1.JPG
High Desert SoCal
93 K1500 burb (personal) 350 AT 3" Lift 250K+
06 F150 Ford (work)
Looking for a 1990's Miata for an engine swap
unplugged is offline   Reply With Quote
Old 11-03-2009, 01:55 PM   #4
remist17
Jr. Apprentice
any luck on the specs I need help on?
Old 11-03-2009, 02:29 PM   #5
Tommygunz
Sr. Apprentice
Tommygunz's Avatar
You can use:
Transmission - Any ATF that meets the Requirments for ATF for that year. Most universals out right now would be great for that
Diffs - 75/90 gear lubes
Transfer case - ATF
Coolant - It woudl depend on whats in their now. THe previous owner could have changed it already and there are different types. do some research and find out what you have.
__________________
-2008 Taho LT1
Old 11-04-2009, 09:25 AM   #6
remist17
Jr. Apprentice
Quote:
Originally Posted by Tommygunz View Post
You can use:
Transfer case - ATF
Thans for the help.
I was hoping someone could point out to me what the type of ATF this year uses and coolant. Again I have no owners manual with the truck that I can referance. I also just dont want to assume the fluid in the truck from the other owner is correct.
Old 11-04-2009, 09:29 AM   #7
vncj96
Legend
Points: 6,891, Level: 54 Points: 6,891, Level: 54 Points: 6,891, Level: 54
Activity: 58% Activity: 58% Activity: 58%
vncj96's Avatar
vncj96 is a glorious beacon of light
I wouldnt worry about the fluids, they are designed to go 100,000mi. Unless you have break down in one of those areas that would require draining to fix than dont worry about them. For most of the fluids you can look under the hood near the latch on top of the grill, there is a diagram of the serpentine belt, spark plug gapping, rad. fluid and many other things you would need so that its easier to find.
__________________
99 K1500 Suburban LT "The Beast"
5.7 K&N & True Dual Exhaust
Hypertech III
BFG AT 285/75/16
___________________________
Jason
vncj96 is offline   Reply With Quote
Old 11-04-2009, 12:49 PM   #8
Tommygunz
Sr. Apprentice
Tommygunz's Avatar
I can tell you that Amsoil's universal ATF will work in your truck. It is compliant with Many auto transmissions over a broad manufacturer date range.
__________________
-2008 Taho LT1
Old 11-04-2009, 01:19 PM   #9
remist17
Jr. Apprentice
thanks all....
Old 11-04-2009, 04:55 PM   #10
dsfloyd
Sr. Engineer
Points: 1,307, Level: 20 Points: 1,307, Level: 20 Points: 1,307, Level: 20
Activity: 51% Activity: 51% Activity: 51%
dsfloyd's Avatar
dsfloyd is a glorious beacon of light
In another post I think remist17 said it had the autotrack and if so I think the transfer case would require GMs autotrack fluid and not ATF. and the coolant is probably dexcool
__________________
2004 Silverado 2500 Crew Cab 4x4, Airraid cold air intake, Throttle body spacer, Magnaflow exhaust, 6" ProComp lift, MX6 Shocks, 35's and 4.10 gears, Rhino Liner.
1960 Land Rover Series II 88
2002 Nissan Altima (wife's Car)
dsfloyd is offline   Reply With Quote
Reply
Bookmarks
Tags
2005-, owner, question, tahoe
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
vBulletin Skin by CompletevB
Copyright 2004 - 2008 GMTruckClub.com - This site is for entertainment purposes only
Ad Management by RedTyger
