Chevy Truck Parts on eBay
Chevy Truck Forum - GMTruckClub.com » Tech Discussions » General Tech Q&A » gas mileage help PLEASE!!!
Reply
Thread Tools Display Modes
Old 11-02-2009, 07:00 PM   #1
Natch
Newbie
Points: 695, Level: 13 Points: 695, Level: 13 Points: 695, Level: 13
Activity: 2% Activity: 2% Activity: 2%
Natch is a glorious beacon of light
Unhappy gas mileage help PLEASE!!!
Need some help here.
I have a gorgeous 2002 Silverado, Z-71 LT with a 5.3 engine, 3.73 gears and only 53K miles.
Before I started making what I thought were gas mileage improvements, I was getting 15.8 MPG. Had a low neutral idle at 500 RPM and a slight miss every now and then, but only at idle. Otherthan that miss, she ran great. I have since gone to a flowmaster delta50 mufler into duals, a K&N air filter and I just put some iridium NGKs (.040 gap) and new high end Moroso wires and my mileage did not change. I use Lucas fuel system cleaner now and then and I still have the miss and lousy mileage. Easy acceleration and 60 on the hiway, etc...
What am I missing here?
Thanks in advance for any assistance provided.
Natch is offline   Reply With Quote
Old 11-02-2009, 07:21 PM   #2
DIGS16
Sr. Mechanic
Points: 736, Level: 14 Points: 736, Level: 14 Points: 736, Level: 14
Activity: 50% Activity: 50% Activity: 50%
DIGS16's Avatar
DIGS16 is a glorious beacon of light
do u have ur exhaust straight out the back and not slightly bent behind the rear tires? i heard if u have them straight out the back u get worse fuel milage...
__________________
2004 Chevy Silverado 1500 Ext
Exhaust w/Chrome Tip
2 In. Rear Shackle Drop
Window Tint
HID Light Kit-8000K
22" Boss 313 Series
Painted Front Grille & Bowtie
Still to come:
DeBadging
SS Front Bumper
New Door Handles (Grippen GQ Chrome)
DIGS16 is offline   Reply With Quote
Old 11-02-2009, 09:20 PM   #3
SmokeU
Sr. Apprentice
Points: 417, Level: 8 Points: 417, Level: 8 Points: 417, Level: 8
Activity: 5% Activity: 5% Activity: 5%
SmokeU's Avatar
SmokeU is a glorious beacon of light
a programmer should help I would think
but really if you want better fuel millage get a Malibu or something
__________________
2004 Chevy Silverado w/ 5.3L V8 / Z71 / Shorty
http://www.cardomain.com/ride/3241978
Would rather be going to fast then to slow
SmokeU is offline   Reply With Quote
Old 11-03-2009, 08:40 AM   #4
XS ive
Sr. Apprentice
Points: 286, Level: 5 Points: 286, Level: 5 Points: 286, Level: 5
Activity: 13% Activity: 13% Activity: 13%
XS ive's Avatar
XS ive is a glorious beacon of light
Quote:
Why is this so? Lack of back pressure due to a bend?
__________________
Charlie
2008 Silverado Crew Southern Comfort conversion. Her name "XS ive"
SoCo cat back duals and Volant CAI
ARE cap with Yakima rack system
GM rear wheel liners
Other fun stuff:
2006 Suzuki RM250
2005 Suzuki RM65(my sons)
2005 Suzuki Hayabusa... sold :-(
XS ive is offline   Reply With Quote
Old 11-03-2009, 09:24 AM   #5
Mean_Green_95
Master Mechanic
Points: 1,876, Level: 25 Points: 1,876, Level: 25 Points: 1,876, Level: 25
Activity: 8% Activity: 8% Activity: 8%
Mean_Green_95's Avatar
Mean_Green_95 is a glorious beacon of light
Send a message via AIM to Mean_Green_95
Run some Seafoam or some GM TEC through a vacuum line. You might have some carbon buildup which would cause a loss of mileage.
__________________
1995 Cheyenne-My Baby
-TOO much to list
2000 GMC Sierra
-5.3L
-Ebay CAI
-Kenwood KCA-iP200
-BOSS 850
-1 Kicker CVR in a self made box
Mean_Green_95 is offline   Reply With Quote
Old 11-03-2009, 09:30 AM   #6
MTPockets
Sr. Apprentice
Points: 188, Level: 3 Points: 188, Level: 3 Points: 188, Level: 3
Activity: 3% Activity: 3% Activity: 3%
MTPockets's Avatar
MTPockets is a glorious beacon of light
What! Do explain because I'm curious about this. I understand back pressure but I don't understand you statement.
__________________
http://i246.photobucket.com/albums/gg98/bubbasmug/th_DSCF0520.jpg
MTPockets is offline   Reply With Quote
Old 11-03-2009, 02:38 PM   #7
phoebeisis
Sr. Engineer
Points: 4,107, Level: 40 Points: 4,107, Level: 40 Points: 4,107, Level: 40
Activity: 4% Activity: 4% Activity: 4%
Location: River Ridge Louisiana-4 miles W of New Orleans-didn't flood-water stopped 800 yards away.
phoebeisis is a glorious beacon of light
I know it seems counterintuitive, but usually the best gas mileage comes with the OEM components-intake, exhaust, spark plugs and wires.
Part throttle FE shouldn't improve with improvements that decrease intake resistance before the throttle plate , since you have to shut the throttle plate more to get the same amount of fuel and air in the CC. The total intake resistance will be the same. Changing to aftermarket parts can throw off any intake tuning that the OEM engineers have done. You only have a K%N filter-not a CAI, so it shouldn't hurt as long as it isn't over oiled.For reasons know only to GM Delco plugs usually work best.
The exhaust system mods probably hurt the exhaust tuning efforts of the OEM engineers.It can hurt part throttle FE.
Your mods didn't cause the miss-get it scanned to see which cylinder is missing.Could be anything electrical-coil etc.It could even be a poor contact where the FE is plugged in.
I would find the miss first-electrical or maybe FI .
Your mods shouldn't really do much either way in respect to part throttle FE, beside, it probably sounds good,and you already own them.
Find the miss- that is the cause of your FE problems. You had it before your mods, so it isn't your mods.What is your idle supposed to be? 500 seems a bit low? It could sure have something to do with the miss and poor FE.
Charlie
ps-You aren't using coolant, are you?
__________________
1998 suburban-
1/2 ton
199500 miles
River
Ridge,LA
phoebeisis is offline   Reply With Quote
Old 11-03-2009, 05:46 PM   #8
DIGS16
Sr. Mechanic
DIGS16's Avatar
Quote:
From what i understood when i went to get my exhaust put on by a friend that owns a muffler shop is that if the pipes go straight out the back to the bed of ur truck, it has easier exit and no pressure going back to the engine, and thus the engine runs more free and spend more gas... obviously better performance but worse gas milage... thats how i understood it and thats y i went with just one side exit pipe lol cuz i cant deal with losing more mpg...
__________________
Window Tint
HID Light Kit-8000K
22" Boss 313 Series
Still to come:
DeBadging
SS Front Bumper
Old 11-03-2009, 06:17 PM   #9
silveradotrailblazer
Master Mechanic
Points: 2,219, Level: 28 Points: 2,219, Level: 28 Points: 2,219, Level: 28
Activity: 20% Activity: 20% Activity: 20%
silveradotrailblazer is a glorious beacon of light
Cool gas mileage help Please!!
X2 what mean green95 said and try taking off your throttlebody and clean front and back of the throttlebody with a throttlebody cleaner and a SOFT brush, old toothbrush works good. Make sure you use a t/body cleaner and not a carb cleaner. Also clean the MAF sensor with MAF cleaner only. CRC makes a great cleaner for both.
silveradotrailblazer is offline   Reply With Quote
Old 11-03-2009, 06:29 PM   #10
TJbear
Sr. Apprentice
Points: 430, Level: 8 Points: 430, Level: 8 Points: 430, Level: 8
TJbear is a glorious beacon of light
I also have a slightly bumpy idle. Cleaned the TB recently due to a sticky gas pedal (which fixed that) but didn't help with the bumpy idle. Also cleaned the MAF. Will be doing the plugs and wires at some point as they are original.
__________________
2000 GMC Sierra Z71 ext. cab w/5300, 70K miles
TJbear is offline   Reply With Quote
Reply
Bookmarks
Tags
mileage, please!!!
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
vBulletin Skin by CompletevB
Copyright 2004 - 2008 GMTruckClub.com - This site is for entertainment purposes only
Ad Management by RedTyger
