01"Silverado With Front-End Rotational Noise??
Discussion in 'General Chevy & GM Tech Questions' started by scalexander, Sep 21, 2013.
  1. scalexander
    scalexander New Member
    I have a 2001 silverado 4x4 5.3l extended cab. Just recently it started to make a noise in the front end when driving, it only makes the noise while going forward. No noise in reverse or when turning in either direction in drive or reverse. Its a rotational noise? with speed of truck.:grrrrrr:
  2. rileyjr16
    Is it 4wd or 2wd?
    - - - Updated - - -
    And what kind of noise? Rubbing? Clicking? Metallic banging? Need a little more info
  3. 99'HEARTBEAT
    ****THREAD MOVED****
    To The
    GENERAL CHEVY/GM TECH SECTION
    In this Section of the Forum, you will receive more Reply's and Advice.
  4. scalexander
    kind of a rubbing grinding noise and as far as drive 4x4 says it all
  5. rileyjr16
    Wheel bearing, brake pads rubbing, cb joints there's a lot of things that can be making this noise. Is your ABS light on?
  6. Pikey
    It could be a brake backing plate rubbing. Does the sound change when you put it in 4x4?
