02' Silverado, aftermarket deck won't hold presets
Discussion in 'Audio, Video & Gadget Tech' started by danegerous, Apr 11, 2009.
  1. danegerous
    danegerous New Member
    Hello all, I recently replaced a sketch Panasonic deck with a new Pioneer mp3 deck. The panasonic wouldn't hold presets so I figured a new deck would solve the problems but not quite...new deck is doing the same thing. Everything works fine just after the truck is off for more then 2 minutes the stations reset. Any ideas?
    Thanks for reading! :eek:uch:
  2. retired
    retired Rockstar 100 Posts
    No power the the constant hot wire.
  3. danegerous
    Which wire would that be? The thick green one? I figured if the deck works, the constant wire should be getting juice...
  4. pmf608
    Your stereo system has a 12V switched (usually yellow - i think) and a 12V constant (usually red - or these colors are vise-versa). These are the harness adapter colors - i have no idea on the trucks wiring. It only needs the switched to operate. The constant is to hold the presets. This problem should go with the clock not staying set. Check your wire color chart or whatever source you got your wire colors from and make sure that the constant power is connected. hope this helps and good luck getting it working.
  5. 04blackz71
    04blackz71 Rockstar 100 Posts
    you need to hook up the red and yellow wires
  6. vncj96
    Agreed you didnt get the constant powered correctly its a red or yellow wire
  7. danegerous
    All the wires are hooked up from the deck....would anyone happen to know what color the constant wire is from the stock harness? Thanks for all the knowledge guys, I appreciate it
  8. vncj96
    Radio Constant 12V+ Wire: Orange
    Radio Ignition Switched 12V+ Wire: Class 2 Serial Data
    Radio Ground Wire: Black/White
    Radio Illumination Dimmer Wire: N/A
    Radio Antenna Trigger Wire: N/A
    Radio Amplifier Trigger Wire: Pink
    Front Speakers Size: N/A
    Front Speakers Location: N/A
    Left Front Speaker Wire (+): Tan
    Left Front Speaker Wire (-): Gray
    Right Front Speaker Wire (+): Light Green
    Right Front Speaker Wire (-): Dark Green
    Rear Speakers Size: N/A
    Rear Speakers Location: N/A
    Left Rear Speaker Wire (+): Brown
    Left Rear Speaker Wire (-): Yellow
    Right Rear Speaker Wire (+): Dark Blue
    Right Rear Speaker Wire (-): Light Blue
    GOOGLE is great ,it took me under two minutes, depending on your options the speaker wiring may be different but everything will be the same (constant, switched, ground). i just googled "02 silverado stereo wiring" if youneed more just use a few different variations of what I typed in google. Any repair manual will have a full diagram as well.
